Re: Just purchased Hurst Comp Plus shifter for install...
[Re: Bill MeLater]
#465770
09/11/09 05:40 PM
09/11/09 05:40 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I bought a new one in the spring and hated it. I had an old "sloppy" one that I welded uo the shifter rod holes and moved 'em up .300" to shorten the throw. I love it,NEVER miss a shift. sometimes sloppy is better.
moved them UP ??? Hurst LOWERED the holes to shorten the throw for the 70 B body pistol grip ???
[Re: John_Kunkel]
#465773
09/11/09 07:48 PM
09/11/09 07:48 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Get a pack of Hurst clips and washers for it.I installed them in my 65 and couldnt believe how it tightened up the shifts.Rocky
Chrysler Firepower
[Re: therocks]
#465774
09/11/09 08:24 PM
09/11/09 08:24 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Make your own rods out of 1/2" steel with teflon raced ball joints at both ends.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: 70sixpkrt]
#465777
09/12/09 08:06 AM
09/12/09 08:06 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Well the new shifter I purchased from Summit Racing looks exactly like my old sloppy shifter...even has the same part# The new one has the short levers just like my old one does which I have found out through this thread is not original to my 70 Charger RT 4speed car...so the new one must also be a reproduction of the 69 Bbody type shift mechanism The new one does have the positive stops already on it though. I will call Brewers to get a set of those modified shift levers as I sure would like a shorter pattern for shifting!
[Re: JohnRR]
#465781
09/12/09 11:38 AM
09/12/09 11:38 AM
Blakcharger440
Wichita,KS
what type of shifter do you have , pistol grip ? if so you need the one in the picture abaove wit hthe LONGER levers to SHORTEN the throw . If you are comparing the sloppy feel to a NEW CARs shifter feel , a trans wit han INTERNAL SHIFT RAIL ... DON'T , you'll NEVER get that feel ...
I have the pistolgrip shifter and the round ball shifter that came in the kit.
I did see the pic above of the mechanism with the longer levers....but I thought that those modified levers from Brewers would help shorten the throw? Since I probably will not be able to find an original 70 pistol grip shifter mechanism that is in good shape...thats why I purchased the new shifter then I could just use those small levers from Brewers?
[Re: Blakcharger440]
#465783
09/12/09 09:39 PM
09/12/09 09:39 PM
JohnRR
U.S.S.A.
Call Brewer , he MIGHT have one of those shifter boxes , or Passon , but it won't be cheap without a core .
[Re: CJK440]
#465784
09/12/09 09:41 PM
09/12/09 09:41 PM
JohnRR
U.S.S.A.
Ahhh, wouldn't say that....
My old cuda had a brandy new Comp Plus shifter box (the B body one they sell) with my own 1/2 steel shift rods with zero slop rod ends, on a ball detent side cover. I swapped out the A833 for a tremec TKO600 with the internal rail shifter (not with the keisler or other offset linkage) and was kinda disappointed. Wasn't as "solid" as the A833 setup I had on before.
The Challenger I have now has the same setup. Beautiful.
Not everyone is as handy as you ... or the guy that the laws of psyhics don't apply to ...
[Re: tecmopar]
#465787
09/13/09 03:29 PM
09/13/09 03:29 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
