Slant 6 guys I have a couple of ?. #436860
08/13/09 03:48 PM
08/13/09 03:48 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
My /6 runs great in the morning or when I just fire up the motor but after it gets hot it won't idle. The carb is hot as heck!!
2nd ? What should the timing be set at for stock?
3. What is the hot or cold lash?
4. Where is the best place to get info on these things?
thx Diego
Re: Slant 6 guys I have a couple of ?. [Re: Diego_Ted] #436861
08/13/09 03:52 PM
08/13/09 03:52 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
www.slantsix.org
Diego What part of Diego are you in... I work in Old Town, live in Oside.....
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Slant 6 guys I have a couple of ?. [Re: Noblewk] #436862
08/13/09 10:15 PM
08/13/09 10:15 PM
Diego-Town, CA
Diego-Town, CA
Hey, thx for the link, I am in Chula!! lOL
Send me a PM and let's get togeather.
Ted
Re: Slant 6 guys I have a couple of ?. [Re: Diego_Ted] #436863
08/13/09 10:18 PM
08/13/09 10:18 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Do the fuel line mod over there at www.slantsix.org
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Slant 6 guys I have a couple of ?. [Re: Rug_Trucker] #436864
08/14/09 01:52 AM
08/14/09 01:52 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I also made an aluminum heat dissapation plate from some sheet aluminum and 2 of the thicker base gaskets. It helped more than doing the fuel line mod, which left me with the same symptoms.
The ideal way is to do both of those mods and add a return line from a 3 nipple fuel filter to the tank to bleed off the residual fuel pressure between the fuel pump and the needle and seat, once the car is shut off.
This bypass line reduces the volume of gas that drips into the intake when the car is shut off and the fuel boils into the intake causing hard starting condition. The fuel in the carb is still going to make it in there, but at least the presurized fuel in the line can't keep flowing past the needle and seat to add more fuel to the problem, because the presure will have been relieved and that fuel sent back to the tank. It also affords some cooling of the fuel by allowing some circulation.
I need to replace my fuel tank anyway, and bought all the parts to do that and plumb the new return line at the same time. Now, I just need to get out and install it. The heat plate eliminated most of my hot start problems.
Re: Slant 6 guys I have a couple of ?. [Re: Diego_Ted] #436865
08/14/09 02:02 AM
08/14/09 02:02 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
are you a member of the local mopar club? there,s acouple of guys in it that are really savy on the /6 they meet almost every sat in clairmont. also they are having thier anual car shor in carlsbad on the 12 of sept.
Re: Slant 6 guys I have a couple of ?. [Re: Rug_Trucker] #436866
08/14/09 11:37 AM
08/14/09 11:37 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
I personally think this is this biggest joke out there, It didn't do jack dooky for me. I think it's more of a gas problem than anything else. I have pics of the plate that someone made on the / board, one of these years I'll get around to trying that idea. Maybe even wrap the manifold with headder tape to keep the heat down.
Re: Slant 6 guys I have a couple of ?. [Re: stubbs300 ] #436867
08/14/09 11:46 AM
08/14/09 11:46 AM
Rug_Trucker Offline
Rug_Trucker  Offline
I shot my fuel line and carb with an infared gauge on my Dart without the mod. 180*!!!!!!! It is hot before it gets to the carb.
My Duster had the problem too. I did the mod when I went 2bbl. No problems. I have never shot temp on the Duster.
Re: Slant 6 guys I have a couple of ?. [Re: Rug_Trucker] #436868
08/14/09 12:29 PM
08/14/09 12:29 PM
Diego-Town, CA
Diego-Town, CA
Cool guys I appriciate the info, I will try them all as the cost is minimal, Stubbs do you have the pic of the plate. What to you do lay a gasket down and cut out the voids and then use a gasket top and bottom?
Yes I am a mem of the SD mopar club and I know the guys you are talking about.
thx Ted
Re: Slant 6 guys I have a couple of ?. [Re: Diego_Ted] #436869
08/14/09 02:08 PM
08/14/09 02:08 PM
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Stubbs do you have the pic of the plate? thx Ted
Ted- Disregard the PM I sent you as I found your E-mail address. Check your Yahoo mail.
Re: Slant 6 guys I have a couple of ?. [Re: stubbs300 ] #436870
08/14/09 03:57 PM
08/14/09 03:57 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Also check the heat riser.
I'd suggest doing a full on tuneup.
Most of those little things get a basic plugs and points and keep running.
Get everything set up, new ignition parts, freshened carb, clean all the grounds and wiring connections, lube all the moving parts, and it's amazing how they respond to some TLC!
Re: Slant 6 guys I have a couple of ?. [Re: RodStRace] #436871
08/14/09 10:09 PM
08/14/09 10:09 PM
Crank it off & lock it there. 10 BTDC might get you started. .010" intakes. .020 exhausts
Re: Slant 6 guys I have a couple of ?. [Re: RapidRobert] #436872
08/14/09 11:56 PM
08/14/09 11:56 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Good advise here.
I went 19.40 with a stock '68 V200 when I first bought it.
When going thru everything, I found the heat riser on was stuck shut, timing was at 4* before with 24* in the dist(28* total), the valves averaged .013/.025, all of it going out a 1.875 exh pipe.
I freed up the riser, set the timing to 12* before with 18* in the dist(30* total), reset the valves to .010/.020, went to a 2.25 pipe and cheap turbo muff.
Went 18.10 next time out.
Re: Slant 6 guys I have a couple of ?. ((Update)) [Re: B5 Bee] #436873
08/15/09 08:58 PM
08/15/09 08:58 PM
Diego-Town, CA
Diego-Town, CA
OK, set the lash, had a couple of exh too tight and a couple of intakes too loose, Did both the fuel line and the heat shield under the carb mod with a single gasket under the shield and a double gasket under the carb and wa la no more rough idle under hot stop and go conditions. I did have the fuel pump take a dump after the fuel line mod!! :x :x
THanks for all the help and lets see what I need to do next?? LOL
Diego
Re: Slant 6 guys I have a couple of ?. ((Update)) [Re: Diego_Ted] #436874
08/15/09 09:21 PM
08/15/09 09:21 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Diego
Erson cam swap, Dutra Duals, 2bbl shift kit 3000 stall and N20
Or maybe a cheapy $30 Chinese chrome valve cover!
That's a '65 318 or 273 BBD I rebuilt from the grave. Sort of polished it. I smoothed everything inside it to increase flow. Probably picked up 4 CFM
Re: Slant 6 guys I have a couple of ?. ((Update)) [Re: Diego_Ted] #436875
08/15/09 09:32 PM
08/15/09 09:32 PM
Lake George
blue195 Offline
blue195  Offline
Lake George
Diego
Yank it out, sell it on craigslist, and drop in a 360.
Re: Slant 6 guys I have a couple of ?. ((Update)) [Re: blue195] #436876
08/16/09 11:17 AM
08/16/09 11:17 AM
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
I'd be willing to bet your problem was with the lash. Enjoy!
Re: Slant 6 guys I have a couple of ?. ((Update)) [Re: blue195] #436877
08/16/09 12:51 PM
08/16/09 12:51 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
... and join the lemming brigade...
