Also check the heat riser. I'd suggest doing a full on tuneup. Most of those little things get a basic plugs and points and keep running. Get everything set up, new ignition parts, freshened carb, clean all the grounds and wiring connections, lube all the moving parts, and it's amazing how they respond to some TLC!
