Re: Slant 6 guys I have a couple of ?.
[Re: Diego_Ted]
#436861
08/13/09 03:52 PM
08/13/09 03:52 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
www.slantsix.orgDiego What part of Diego are you in... I work in Old Town, live in Oside.....
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: Rug_Trucker]
#436864
08/14/09 01:52 AM
08/14/09 01:52 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Do the fuel line mod over there at www.slantsix.org
I also made an aluminum heat dissapation plate from some sheet aluminum and 2 of the thicker base gaskets. It helped more than doing the fuel line mod, which left me with the same symptoms.
The ideal way is to do both of those mods and add a return line from a 3 nipple fuel filter to the tank to bleed off the residual fuel pressure between the fuel pump and the needle and seat, once the car is shut off.
This bypass line reduces the volume of gas that drips into the intake when the car is shut off and the fuel boils into the intake causing hard starting condition. The fuel in the carb is still going to make it in there, but at least the presurized fuel in the line can't keep flowing past the needle and seat to add more fuel to the problem, because the presure will have been relieved and that fuel sent back to the tank. It also affords some cooling of the fuel by allowing some circulation.
I need to replace my fuel tank anyway, and bought all the parts to do that and plumb the new return line at the same time. Now, I just need to get out and install it. The heat plate eliminated most of my hot start problems.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Rug_Trucker]
#436866
08/14/09 11:37 AM
08/14/09 11:37 AM
Posts: 1,181 Lost in the ozone again
stubbs300
Vacation
Vacation
I personally think this is this biggest joke out there, It didn't do jack dooky for me. I think it's more of a gas problem than anything else. I have pics of the plate that someone made on the / board, one of these years I'll get around to trying that idea. Maybe even wrap the manifold with headder tape to keep the heat down.
[Re: stubbs300 ]
#436867
08/14/09 11:46 AM
08/14/09 11:46 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I shot my fuel line and carb with an infared gauge on my Dart without the mod. 180*!!!!!!! It is hot before it gets to the carb.
My Duster had the problem too. I did the mod when I went 2bbl. No problems. I have never shot temp on the Duster.
[Re: Diego_Ted]
#436869
08/14/09 02:08 PM
08/14/09 02:08 PM
stubbs300
Vacation
Vacation
Stubbs do you have the pic of the plate? thx Ted
Ted- Disregard the PM I sent you as I found your E-mail address. Check your Yahoo mail.
[Re: stubbs300 ]
#436870
08/14/09 03:57 PM
08/14/09 03:57 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Also check the heat riser. I'd suggest doing a full on tuneup. Most of those little things get a basic plugs and points and keep running. Get everything set up, new ignition parts, freshened carb, clean all the grounds and wiring connections, lube all the moving parts, and it's amazing how they respond to some TLC!
[Re: RapidRobert]
#436872
08/14/09 11:56 PM
08/14/09 11:56 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Crank it off & lock it there. 10 BTDC might get you started. .010" intakes. .020 exhausts
Good advise here. I went 19.40 with a stock '68 V200 when I first bought it. When going thru everything, I found the heat riser on was stuck shut, timing was at 4* before with 24* in the dist(28* total), the valves averaged .013/.025, all of it going out a 1.875 exh pipe. I freed up the riser, set the timing to 12* before with 18* in the dist(30* total), reset the valves to .010/.020, went to a 2.25 pipe and cheap turbo muff. Went 18.10 next time out.
Re: Slant 6 guys I have a couple of ?. ((Update))
[Re: Diego_Ted]
#436875
08/15/09 09:32 PM
08/15/09 09:32 PM
Posts: 69 Lake George
blue195
Lake George
THanks for all the help and lets see what I need to do next?? LOL
Diego
Yank it out, sell it on craigslist, and drop in a 360.
[Re: blue195]
#436877
08/16/09 12:51 PM
08/16/09 12:51 PM
Posts: 411 Texas
vynn3
Texas
... and join the lemming brigade...
