N/SS cast Hemi intake. What works?
#3224812
04/03/24 05:36 PM
04/03/24 05:36 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Friend is building a new engine for his 64 Dodge. 485" , Stage 5 heads ported at FHO. 285/2962 112 roller, shooting for compression in the 12-1 range. He has a factory crossram and factory Hemi carbs. Sheet metal intakes arent legal unless you run 9.25 or quicker index. Previously with a smaller cam and Mopar perf heads it ran a best of 9.88. 4.10 gear 3550lbs Doug
Re: N/SS cast Hemi intake. What works?
[Re: dvw]
#3224830
04/03/24 06:35 PM
04/03/24 06:35 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
Is that an original 1964 to 1968 Mopar single piece SS crossram intake (aluminum or 1965 magnesium) or the later over the counter only two piece crossram intake?
[Re: dvw]
#3224847
04/03/24 07:25 PM
04/03/24 07:25 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Friend is building a new engine for his 64 Dodge. 485" , Stage 5 heads ported at FHO. 285/2962 112 roller, shooting for compression in the 12-1 range. He has a factory crossram and factory Hemi carbs. Sheet metal intakes arent legal unless you run 9.25 or quicker index. Previously with a smaller cam and Mopar perf heads it ran a best of 9.88. 4.10 gear 3550lbs Doug I am a small block guy, but wow, seems like a ton of camshaft for a 12 to 1 485 inch deal. Especially for a heavy car.
[Re: d330]
#3224889
04/03/24 09:58 PM
04/03/24 09:58 PM
Posts: 4,579 Motor City
6PKRTSE
Motor City
Barton cast cross ram will work nicely.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DoubleD]
#3224934
04/04/24 08:04 AM
04/04/24 08:04 AM
dvw
MI, usa
The cam was speced by Tim at FHO. I haven't seen the specs on paper. Just going on what I was told. My mistake on the current intake. The intake is 2 piece aluminum. I believe it is the Mopar Performance intake. Doug
[Re: d330]
#3224936
04/04/24 08:08 AM
04/04/24 08:08 AM
dvw
MI, usa
I run the m.p cross-ram with the removable tops with the holly 770’s carbs Very happy with the performance. I have 2 64 330’s Both have 540 c.i engines One at 3250 lbs. best 8.92@151 2nd at 3700 lbs.best 9.44@145 I believe this is the same set up. Do you have any starting jetting info? Doug
[Re: dvw]
#3224939
04/04/24 08:24 AM
04/04/24 08:24 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
the barton one makes more power than a unmodified mopar perfomance one. we run a modified mopar which probably makes equal to the barton. we have been 8.76@153 3400 lbs
JAKES AUTOMOTIVE
