N/SS cast Hemi intake. What works? #3224812
04/03/24 05:36 PM
04/03/24 05:36 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Friend is building a new engine for his 64 Dodge. 485" , Stage 5 heads ported at FHO. 285/2962 112 roller, shooting for compression in the 12-1 range. He has a factory crossram and factory Hemi carbs. Sheet metal intakes arent legal unless you run 9.25 or quicker index. Previously with a smaller cam and Mopar perf heads it ran a best of 9.88. 4.10 gear 3550lbs
Doug
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224828
04/03/24 06:31 PM
04/03/24 06:31 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Barton cast cross ram.
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224830
04/03/24 06:35 PM
04/03/24 06:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Is that an original 1964 to 1968 Mopar single piece SS crossram intake (aluminum or 1965 magnesium) or the later over the counter only two piece crossram intake?
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224847
04/03/24 07:25 PM
04/03/24 07:25 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Doug
I am a small block guy, but wow, seems like a ton of camshaft for a 12 to 1 485 inch deal. Especially for a heavy car.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: N/SS cast Hemi intake. What works? [Re: Cab_Burge] #3224851
04/03/24 07:39 PM
04/03/24 07:39 PM
Cedar Lake,IN
d330 Offline
d330  Offline
Cedar Lake,IN
I run the m.p cross-ram with the removable tops with the holly 770’s carbs
Very happy with the performance.
I have 2 64 330’s Both have 540 c.i engines
One at 3250 lbs. best 8.92@151
2nd at 3700 lbs.best 9.44@145
Re: N/SS cast Hemi intake. What works? [Re: d330] #3224889
04/03/24 09:58 PM
04/03/24 09:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Barton cast cross ram will work nicely.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: N/SS cast Hemi intake. What works? [Re: 6PKRTSE] #3224933
04/04/24 07:30 AM
04/04/24 07:30 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The Barton crossram is probably the best cast crossram type intake outside of the MP intake - I run the Stage V inline intake - there is also an edelbrock inline intake made for the Victor Jr. heads but has less plenum volume than the Stage V . I would take a second look at that cam - that's a huge cam! Mine is way smaller than that one
Re: N/SS cast Hemi intake. What works? [Re: DoubleD] #3224934
04/04/24 08:04 AM
04/04/24 08:04 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The cam was speced by Tim at FHO. I haven't seen the specs on paper. Just going on what I was told. My mistake on the current intake. The intake is 2 piece aluminum. I believe it is the Mopar Performance intake.
Doug
Re: N/SS cast Hemi intake. What works? [Re: d330] #3224936
04/04/24 08:08 AM
04/04/24 08:08 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I believe this is the same set up. Do you have any starting jetting info?
Doug
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224939
04/04/24 08:24 AM
04/04/24 08:24 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
the barton one makes more power than a unmodified mopar perfomance one. we run a modified mopar which probably makes equal to the barton. we have been 8.76@153 3400 lbs
JAKES AUTOMOTIVE
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3225059
04/04/24 04:30 PM
04/04/24 04:30 PM
Cedar Lake,IN
d330 Offline
d330  Offline
Cedar Lake,IN
Number 68 jets both carbs.
