N/SS cast Hemi intake. What works? #3224812
04/03/24 05:36 PM
04/03/24 05:36 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Friend is building a new engine for his 64 Dodge. 485" , Stage 5 heads ported at FHO. 285/2962 112 roller, shooting for compression in the 12-1 range. He has a factory crossram and factory Hemi carbs. Sheet metal intakes arent legal unless you run 9.25 or quicker index. Previously with a smaller cam and Mopar perf heads it ran a best of 9.88. 4.10 gear 3550lbs
Doug
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224828
04/03/24 06:31 PM
04/03/24 06:31 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Barton cast cross ram.
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224830
04/03/24 06:35 PM
04/03/24 06:35 PM
Is that an original 1964 to 1968 Mopar single piece SS crossram intake (aluminum or 1965 magnesium) or the later over the counter only two piece crossram intake?
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224847
04/03/24 07:25 PM
04/03/24 07:25 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Doug
I am a small block guy, but wow, seems like a ton of camshaft for a 12 to 1 485 inch deal. Especially for a heavy car.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: N/SS cast Hemi intake. What works? [Re: Cab_Burge] #3224851
04/03/24 07:39 PM
04/03/24 07:39 PM
Cedar Lake,IN
d330 Offline
d330  Offline
Cedar Lake,IN
I run the m.p cross-ram with the removable tops with the holly 770’s carbs
Very happy with the performance.
I have 2 64 330’s Both have 540 c.i engines
One at 3250 lbs. best 8.92@151
2nd at 3700 lbs.best 9.44@145
Re: N/SS cast Hemi intake. What works? [Re: d330] #3224889
04/03/24 09:58 PM
04/03/24 09:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Barton cast cross ram will work nicely.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: N/SS cast Hemi intake. What works? [Re: 6PKRTSE] #3224933
04/04/24 07:30 AM
04/04/24 07:30 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The Barton crossram is probably the best cast crossram type intake outside of the MP intake - I run the Stage V inline intake - there is also an edelbrock inline intake made for the Victor Jr. heads but has less plenum volume than the Stage V . I would take a second look at that cam - that's a huge cam! Mine is way smaller than that one
Re: N/SS cast Hemi intake. What works? [Re: DoubleD] #3224934
04/04/24 08:04 AM
04/04/24 08:04 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
The cam was speced by Tim at FHO. I haven't seen the specs on paper. Just going on what I was told. My mistake on the current intake. The intake is 2 piece aluminum. I believe it is the Mopar Performance intake.
Doug
Re: N/SS cast Hemi intake. What works? [Re: d330] #3224936
04/04/24 08:08 AM
04/04/24 08:08 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I believe this is the same set up. Do you have any starting jetting info?
Doug
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3224939
04/04/24 08:24 AM
04/04/24 08:24 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
the barton one makes more power than a unmodified mopar perfomance one. we run a modified mopar which probably makes equal to the barton. we have been 8.76@153 3400 lbs
JAKES AUTOMOTIVE
Re: N/SS cast Hemi intake. What works? [Re: dvw] #3225059
04/04/24 04:30 PM
04/04/24 04:30 PM
Cedar Lake,IN
d330 Offline
d330  Offline
Cedar Lake,IN
Number 68 jets both carbs.
