AN fitting question #3196036
12/08/23 10:40 AM
12/08/23 10:40 AM
NW Illinois
MoonshineMattK Offline OP
NW Illinois
Hello all,
I have been searching for a T fitting with the following configuration
#1 3/8npt
#2 -8 swivel as in position #4
#3 -8 male
Is such a thing available or do I just use a swivel union in position #2?
Thanks, Matthew
Re: AN fitting question [Re: MoonshineMattK] #3196038
12/08/23 10:44 AM
12/08/23 10:44 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I believe it exists, but that's all I have to offer.
Re: AN fitting question [Re: jcc] #3196049
12/08/23 11:51 AM
12/08/23 11:51 AM
NW Illinois
NW Illinois
Hen's teeth so far. I'm batting zero
Re: AN fitting question [Re: MoonshineMattK] #3196060
12/08/23 12:24 PM
12/08/23 12:24 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Have you tried Earl's and Aeroquip ?
Re: AN fitting question [Re: topside] #3196065
12/08/23 12:42 PM
12/08/23 12:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: AN fitting question [Re: MoonshineMattK] #3196067
12/08/23 12:52 PM
12/08/23 12:52 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Looking through the Russell (Edelbrock) catalog and I’m not seeing it as a single fitting. Either a union like you said, or Russell part number 614308 and 614218 shruggy
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: AN fitting question [Re: metallicareload] #3196070
12/08/23 01:04 PM
12/08/23 01:04 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
XRP and Fragola have more of the custom odd ball stuff.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: AN fitting question [Re: MoonshineMattK] #3196076
12/08/23 01:42 PM
12/08/23 01:42 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
925108 along with a 916108 is as close as I could come up with... there are different vendors but here is what I could find
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: AN fitting question [Re: Al_Alguire] #3196077
12/08/23 01:43 PM
12/08/23 01:43 PM
NW Illinois
NW Illinois
Close, hoping to find one with a swivel
Re: AN fitting question [Re: W.I.N. Racing] #3196078
12/08/23 01:44 PM
12/08/23 01:44 PM
NW Illinois
NW Illinois
Thank you, I have those already. Was hoping to use the least amount of fittings. So far no luck
Re: AN fitting question [Re: MoonshineMattK] #3196085
12/08/23 02:32 PM
12/08/23 02:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Missed the female end on the T. No one makes one that I’m aware of. So you are looking for 3/8” pipe to -8 female and -8 male on the same fitting correct
Re: AN fitting question [Re: Al_Alguire] #3196099
12/08/23 04:15 PM
12/08/23 04:15 PM
NW Illinois
NW Illinois
You are correct. Hopefully not about the unavailable part though lol
Re: AN fitting question [Re: MoonshineMattK] #3196108
12/08/23 04:36 PM
12/08/23 04:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're really adventurous, you could machine the threads off one side of the 925108 and thread it with a 3/8" NPT die.
Re: AN fitting question [Re: John_Kunkel] #3196120
12/08/23 05:36 PM
12/08/23 05:36 PM
NW Illinois
NW Illinois
That thought crossed my mind. Haven't measured the thread diameter to compare them. Also thought about welding two fittings together. Probably just get the union lol.
Wanted to reach out to the forum first and see if I'd overlooked something.
Appreciate all the help
Re: AN fitting question [Re: MoonshineMattK] #3196257
12/09/23 02:31 PM
12/09/23 02:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A quick check with calipers shows the root diameter of the #8 thread and the diameter of a 3/8" pipe about the same at .667"-.669".
Re: AN fitting question [Re: John_Kunkel] #3196278
12/09/23 03:36 PM
12/09/23 03:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
[Linked Image] and [Linked Image]
or
Re: AN fitting question [Re: CMcAllister] #3196292
12/09/23 04:33 PM
12/09/23 04:33 PM
A collage of whims
A collage of whims
What about changing the fitting on whatever is posing the connection problem ?
Re: AN fitting question [Re: topside] #3196700
12/11/23 02:00 PM
12/11/23 02:00 PM
NW Illinois
NW Illinois
I'm making a bypass around the mechanical fuel pump. The pump threads are 3/8npt.
Rethreading one of the -8 connections to 3/8npt seems like the best option so far. It still needs to be mocked up in the car and that may change things.
