Re: AN fitting question
[Re: MoonshineMattK]
#3196038
12/08/23 10:44 AM
12/08/23 10:44 AM
Posts: 22,783 Bitopia
jcc
Bitopia
I believe it exists, but that's all I have to offer.
[Re: jcc]
#3196049
12/08/23 11:51 AM
12/08/23 11:51 AM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
I believe it exists, but that's all I have to offer. Hen's teeth so far. I'm batting zero
[Re: metallicareload]
#3196070
12/08/23 01:04 PM
12/08/23 01:04 PM
Posts: 4,590 Motor City
6PKRTSE
Motor City
XRP and Fragola have more of the custom odd ball stuff.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
#3196076
12/08/23 01:42 PM
12/08/23 01:42 PM
Posts: 2,125 Byron, NY
W.I.N. Racing
Byron, NY
925108 along with a 916108 is as close as I could come up with... there are different vendors but here is what I could find
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3196078
12/08/23 01:44 PM
12/08/23 01:44 PM
MoonshineMattK
NW Illinois
925108 along with a 916108 is as close as I could come up with... there are different vendors but here is what I could find Thank you, I have those already. Was hoping to use the least amount of fittings. So far no luck
#3196085
12/08/23 02:32 PM
12/08/23 02:32 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
Missed the female end on the T. No one makes one that I’m aware of. So you are looking for 3/8” pipe to -8 female and -8 male on the same fitting correct
[Re: Al_Alguire]
#3196099
12/08/23 04:15 PM
12/08/23 04:15 PM
MoonshineMattK
NW Illinois
Missed the female end on the T. No one makes one that I’m aware of. So you are looking for 3/8” pipe to -8 female and -8 male on the same fitting correct You are correct. Hopefully not about the unavailable part though lol
#3196108
12/08/23 04:36 PM
12/08/23 04:36 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're really adventurous, you could machine the threads off one side of the 925108 and thread it with a 3/8" NPT die.
[Re: John_Kunkel]
#3196120
12/08/23 05:36 PM
12/08/23 05:36 PM
MoonshineMattK
NW Illinois
That thought crossed my mind. Haven't measured the thread diameter to compare them. Also thought about welding two fittings together. Probably just get the union lol. Wanted to reach out to the forum first and see if I'd overlooked something. Appreciate all the help
#3196257
12/09/23 02:31 PM
12/09/23 02:31 PM
John_Kunkel
Rio Linda, CA
A quick check with calipers shows the root diameter of the #8 thread and the diameter of a 3/8" pipe about the same at .667"-.669".
[Re: topside]
#3196700
12/11/23 02:00 PM
12/11/23 02:00 PM
MoonshineMattK
NW Illinois
What about changing the fitting on whatever is posing the connection problem ? I'm making a bypass around the mechanical fuel pump. The pump threads are 3/8npt. Rethreading one of the -8 connections to 3/8npt seems like the best option so far. It still needs to be mocked up in the car and that may change things.
