wiring/terminals Q #3172022
09/01/23 10:10 AM
09/01/23 10:10 AM
RapidRobert Offline OP
Wiring up the stock car. other than the battery to the main cutoff then to the starter which are large welding cables, for general wiring (alt/reg/ignition) is it acceptable to crimp on the terminals or should I crimp & solder them? these are 10 gauge (alt to battery) & the rest are smaller (alt field/reg/ignition) & the crimp on terminals are cheap overseas ones which is all I could find at the time. thank you for your time. RR
Re: wiring/terminals Q [Re: RapidRobert] #3172037
09/01/23 10:54 AM
09/01/23 10:54 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Crimps work fine as long as they are properly done. Its a personal preference
Re: wiring/terminals Q [Re: RapidRobert] #3172038
09/01/23 10:55 AM
09/01/23 10:55 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
When I wired our 70 Charger, I soldered any wire larger than #16.
I figured if they needed to be that large, they carried enough current to justify soldering.
Maybe a good mechanical termination would suffice, but I felt more safe with soldering, weren't that many anyhow.
Joe
Re: wiring/terminals Q [Re: jlatessa] #3172042
09/01/23 11:03 AM
09/01/23 11:03 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No argument with the above.
There are billions of crimped terminals out there working fine, as they were properly done.
I'm not a fan of the crimp terminals that have those big plastic "sleeves".
I use the metal ones - or remove the plastic - slide some shrink-wrap over the wire end, crimp them, and of course heat the shrink wrap.
Must be hundreds I've done that way with no problems.
Re: wiring/terminals Q [Re: topside] #3172045
09/01/23 11:11 AM
09/01/23 11:11 AM
yes that is what I did, removed the plastic covers. I did start to solder em but my small soldering iron is not hot enough & I would have to go get one
Re: wiring/terminals Q [Re: RapidRobert] #3172052
09/01/23 12:01 PM
09/01/23 12:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I should have mentioned that I buy non-insulated terminals; easier on the hands than cutting those plastic covers off laugh2
My local hardware store has them, if I don't need a bulk amount from McMaster-Carr or wherever.
Re: wiring/terminals Q [Re: topside] #3172053
09/01/23 12:11 PM
09/01/23 12:11 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
I Crimp/Solder and heat shrink with adhesive lined tube...every size. I use non insulated connectors from Del-City but there are other suppliers.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: wiring/terminals Q [Re: W.I.N. Racing] #3172073
09/01/23 12:45 PM
09/01/23 12:45 PM
moparx Offline
moparx  Offline
i use the marine grade heat shrink tubing with the adhesive as well.
when crimping, make sure you have a good, correct style crimping tool for the connection you are making. not those ones that come with the eleventybillion piece terminal kit from [insert the country of your choice here] available at all wally worlds and hobo fright.
beer
Re: wiring/terminals Q [Re: moparx] #3172148
09/01/23 06:26 PM
09/01/23 06:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Yes, save yourself headaches and get one of the "ratcheting" crimpers. I got a pair off Amazon for about $30.
Re: wiring/terminals Q [Re: W.I.N. Racing] #3172195
09/01/23 09:42 PM
09/01/23 09:42 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree
Another vote for Del-City non insulated connectors and good quality shrink sleeve. I crimp, solder, and shrink all terminals.
Gus beer
64 Plymouth Savoy
Dana 60
Re: wiring/terminals Q [Re: RapidRobert] #3172202
09/01/23 09:57 PM
09/01/23 09:57 PM
Why not do both work up twocents
Do you have the proper crimping tool for your terminals ends? If not buy one now before starting up wrench twocents
I'm a little anal when it comes to wiring repairs, crimp, solder and heat shrink them all wrench up
Re: wiring/terminals Q [Re: Cab_Burge] #3172203
09/01/23 10:19 PM
09/01/23 10:19 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Uninsulated terminals, crimped, heat shrunk. I haven't soldered any of it in years.
2 ga battery cable, tops. Once the engine starts, anything bigger is just dead weight,
Re: wiring/terminals Q [Re: slantzilla] #3172219
09/01/23 11:47 PM
09/01/23 11:47 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
This.
I want my fair share
Re: wiring/terminals Q [Re: SomeCarGuy] #3172244
09/02/23 09:09 AM
09/02/23 09:09 AM
Good comprehensive info! I will make some changes. thanks guys. RR
Re: wiring/terminals Q [Re: RapidRobert] #3172259
09/02/23 09:59 AM
09/02/23 09:59 AM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
Tin the wire and then crimp it.
Re: wiring/terminals Q [Re: R3 Racing] #3172298
09/02/23 12:11 PM
09/02/23 12:11 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Do not solder. Not a good idea. Ton of info on the net for reference. Tinning the wire is fine, but not a full solder joint.
A quality lug properly crimped will be the best solution. Non-insulated lugs are best.
Re: wiring/terminals Q [Re: markz528] #3172315
09/02/23 01:29 PM
09/02/23 01:29 PM
What is your reasoning about not soldering? shruggy
Corrosion affects many electrical circuit throughout our country that have humidity levels above 35% most of the time work
Soldering eliminates that up scope work
Re: wiring/terminals Q [Re: Cab_Burge] #3172322
09/02/23 01:36 PM
09/02/23 01:36 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Corrosion is an issue with soldering. Very difficult to remove all the flux from a solder joint. The left over flux will cause corrosion over time. Proper crimp with a proper heat shrink (sealant filled heat shrink is best) addresses the corrosion issues.
Biggest problem is cracking. The solder does not do well in vibration environments and a car is a vibration environment.
Bad connections have caused my company millions of dollars in failures over the past decade. We put a team together that addressed the connection problems . The conclusion is a proper sized good quality lug properly crimped is the solution.
Re: wiring/terminals Q [Re: jlatessa] #3172326
09/02/23 01:40 PM
09/02/23 01:40 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Crimp it .
as mentioned do a good job and use quality stuff. It would have to be in a poor atmosphere for a long time for a crimp to fail .
Re: wiring/terminals Q [Re: Wirenut] #3172544
09/03/23 11:25 AM
09/03/23 11:25 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I order most my wiring supplies Del City as well. I also use Duetsch connectors for all my stuff.
