Re: SB 59 Degree Bronze Lifter Bores
[Re: moparmacka]
#3161554
07/21/23 09:45 AM
07/21/23 09:45 AM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
I am wondering if anyone has successfully run solid flat tappet lifters in a 59 degree SB LA with bronze lifters bores and pushrod oiling? I am kind of over the solid roller deal street/strip use with spring pressures and bronze oil pump drive gears. Time for something a little more streetable. Getting old and cranky I run a solid with bushed lifter bores, but don’t pushrod oil.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3161642
07/21/23 01:28 PM
07/21/23 01:28 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Are you having problems with the bronze drives? I run them and get several thousand miles out of them on the street. I run as light of an oil as I can to keep the drag down on it and I drilled a small hole in the oil galley plug that sprays oil directly on the gear.
I would be disappointed in the wear if this were a daily driver but it is just on occasional driver that only sees real miles if I do Drag Week.
68 Barracuda Formula S 340
[Re: moparmacka]
#3161818
07/22/23 03:10 AM
07/22/23 03:10 AM
Posts: 43,214 Bend,OR USA
Cab_Burge
Where your T&D stainless or aluminum bodies? How much spring pressure and how long did they last(approximately)?
[Re: Cab_Burge]
#3164048
07/29/23 09:02 AM
07/29/23 09:02 AM
Posts: 2,512 PA
moparacer
PA
I had issues with the T&D rockers and had them make me a bushed set 4 years ago. Same with lifters. Went to bushed.
No more needle bearings in an engine for me.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
