SB 59 Degree Bronze Lifter Bores #3161520
07/21/23 01:25 AM
07/21/23 01:25 AM
Queensland Australia
moparmacka Offline OP
I am wondering if anyone has successfully run solid flat tappet lifters in a 59 degree SB LA with bronze lifters bores and pushrod oiling? I am kind of over the solid roller deal street/strip use with spring pressures and bronze oil pump drive gears. Time for something a little more streetable. Getting old and cranky
Re: SB 59 Degree Bronze Lifter Bores [Re: moparmacka] #3161554
07/21/23 09:45 AM
07/21/23 09:45 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I run a solid with bushed lifter bores, but don’t pushrod oil.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: SB 59 Degree Bronze Lifter Bores [Re: B3422W5] #3161642
07/21/23 01:28 PM
07/21/23 01:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Are you having problems with the bronze drives? I run them and get several thousand miles out of them on the street. I run as light of an oil as I can to keep the drag down on it and I drilled a small hole in the oil galley plug that sprays oil directly on the gear.
I would be disappointed in the wear if this were a daily driver but it is just on occasional driver that only sees real miles if I do Drag Week.
68 Barracuda Formula S 340
Re: SB 59 Degree Bronze Lifter Bores [Re: Bad340fish] #3161744
07/21/23 07:26 PM
07/21/23 07:26 PM
No, I am pulling the engine down over the next week or so due to failure of a couple of rocker trunion bearings on my T&D’s. I was contemplating going back to a solid flat tappet from the solid roller for a little more durability. But then the reason I went solid roller as I wiped 3 lobes on a flat tappet. What a conundrum.
Just wonder if the bushed bore with an oil hole would provide enough lubrication to face of the lifter.
Re: SB 59 Degree Bronze Lifter Bores [Re: moparmacka] #3161818
07/22/23 03:10 AM
07/22/23 03:10 AM
Where your T&D stainless or aluminum bodies?
How much spring pressure and how long did they last(approximately)?
Re: SB 59 Degree Bronze Lifter Bores [Re: Cab_Burge] #3162107
07/22/23 08:59 PM
07/22/23 08:59 PM
I shouldn’t complain really. Installed them on solid flat tappet late 2017 wiped a lobe. Then built the solid roller engine which was dynoed early 2019 and has been together since. Thousands of street miles, plus 40 or so passes, and lost count on how many roll race type hits we have over here at sanctioned off street car events. Should also mention the idling it cops when street driving.
Springs are at 260 seat and 665 open. Oh and they are aluminium bodies.
Re: SB 59 Degree Bronze Lifter Bores [Re: moparmacka] #3162544
07/23/23 08:36 PM
07/23/23 08:36 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Going back to flat tappet lifters, is it likely you'll have too much lifter bore clearance?
Alan Jones
Re: SB 59 Degree Bronze Lifter Bores [Re: LA360] #3163795
07/28/23 05:30 AM
07/28/23 05:30 AM
I bet I will.
Pulling the engine this weekend and diagnose.
Re: SB 59 Degree Bronze Lifter Bores [Re: moparmacka] #3163869
07/28/23 12:27 PM
07/28/23 12:27 PM
I've heard and seen post on here about all brands of aluminum roller rocker am breaking including Jesel, my next set of race roller rocker arms will be steel, not aluminum from now on up scope
They are more expensive initially but most of the time that money spent saves us down the road later from breaking them and hurting other engine parts when they fail work
Re: SB 59 Degree Bronze Lifter Bores [Re: Cab_Burge] #3164048
07/29/23 09:02 AM
07/29/23 09:02 AM
PA
moparacer Offline
moparacer  Offline
PA
I had issues with the T&D rockers and had them make me a bushed set 4 years ago. Same with lifters. Went to bushed.
No more needle bearings in an engine for me.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: SB 59 Degree Bronze Lifter Bores [Re: moparacer] #3164566
07/31/23 03:10 PM
07/31/23 03:10 PM
My theory also my friend.
