Re: SB 59 Degree Bronze Lifter Bores
[Re: moparmacka]
#3161554
07/21/23 09:45 AM
07/21/23 09:45 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I am wondering if anyone has successfully run solid flat tappet lifters in a 59 degree SB LA with bronze lifters bores and pushrod oiling? I am kind of over the solid roller deal street/strip use with spring pressures and bronze oil pump drive gears. Time for something a little more streetable. Getting old and cranky I run a solid with bushed lifter bores, but don’t pushrod oil.
[Re: B3422W5]
#3161642
07/21/23 01:28 PM
07/21/23 01:28 PM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
Are you having problems with the bronze drives? I run them and get several thousand miles out of them on the street. I run as light of an oil as I can to keep the drag down on it and I drilled a small hole in the oil galley plug that sprays oil directly on the gear.
I would be disappointed in the wear if this were a daily driver but it is just on occasional driver that only sees real miles if I do Drag Week.
68 Barracuda Formula S 340
[Re: moparmacka]
#3161818
07/22/23 03:10 AM
07/22/23 03:10 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
Where your T&D stainless or aluminum bodies? How much spring pressure and how long did they last(approximately)?
[Re: Cab_Burge]
#3164048
07/29/23 09:02 AM
07/29/23 09:02 AM
Posts: 2,524 PA
moparacer
PA
I had issues with the T&D rockers and had them make me a bushed set 4 years ago. Same with lifters. Went to bushed.
No more needle bearings in an engine for me.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
