Re: Indy SR or INDY-1, how to tell what I have
[Re: Moparnut426]
#3080759
09/26/22 09:54 AM
09/26/22 09:54 AM
Posts: 4,102 Yes
sixpakdodge
Yes
I thought the SR used all stock top end components, but the -1 uses offset rockers. Correct. The SR can also use the offset rocker though. As far as markings...I think only if they've been CNC'ed. Otherwise you're at the mercy of measuring everything to try and figure out what they are. Both heads use the same studs/bolts.
[Re: sixpakdodge]
#3080767
09/26/22 10:16 AM
09/26/22 10:16 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I thought the SR used all stock top end components, but the -1 uses offset rockers. Correct. The SR can also use the offset rocker though. As far as markings...I think only if they've been CNC'ed. Otherwise you're at the mercy of measuring everything to try and figure out what they are. Both heads use the same studs/bolts. So I can run the standard rockers on a SR or -1 head?
[Re: sixpakdodge]
#3080773
09/26/22 10:22 AM
09/26/22 10:22 AM
Moparnut426
I thought the SR used all stock top end components, but the -1 uses offset rockers. Correct. The SR can also use the offset rocker though. As far as markings...I think only if they've been CNC'ed. Otherwise you're at the mercy of measuring everything to try and figure out what they are. Both heads use the same studs/bolts. Would a picture help? Ive got 3, nothing into the intake ports though
[Re: Moparnut426]
#3080809
09/26/22 12:11 PM
09/26/22 12:11 PM
Posts: 10,044 MN
JERICOGTX
MN
Thanks guys!!
Ill get the expensive rockers coming LOL
Do I go ahead and use the "indy" specific head studs also then? Mancini shows 2 different ones I assume the deck is thicker on a -1 The 572-13, and 600-13 heads use taller studs. The 440-1's and SR, use the same set, and are taller than stock type heads.
69 GTX
68 Road Runner
