Originally Posted by Moparnut426
I thought the SR used all stock top end components, but the -1 uses offset rockers.
Correct.
The SR can also use the offset rocker though. As far as markings...I think only if they've been CNC'ed. Otherwise you're at the mercy of measuring everything to try and figure out what they are. Both heads use the same studs/bolts.
