Indy SR or INDY-1, how to tell what I have #3080754
09/26/22 09:39 AM
09/26/22 09:39 AM
Finally a HUSKER again
Moparnut426 Offline OP
Customer bought a engine, brought me a bunch of parts, brand new indy heads, but I have no paper work on them, and nothing telling me what they are. I thought the SR used all stock top end components, but the -1 uses offset rockers. are there any markings or cast numbers on them? They are currently at the machine shop getting set up for solid roller, so I dont have them in front of me.
I thought the Indy-1 used special studs too.
Any info is greatly apreciated.
Kasey
Re: Indy SR or INDY-1, how to tell what I have [Re: Moparnut426] #3080759
09/26/22 09:54 AM
09/26/22 09:54 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Correct.
The SR can also use the offset rocker though. As far as markings...I think only if they've been CNC'ed. Otherwise you're at the mercy of measuring everything to try and figure out what they are. Both heads use the same studs/bolts.
Re: Indy SR or INDY-1, how to tell what I have [Re: sixpakdodge] #3080767
09/26/22 10:16 AM
09/26/22 10:16 AM
Correct.
So I can run the standard rockers on a SR or -1 head?
Re: Indy SR or INDY-1, how to tell what I have [Re: sixpakdodge] #3080773
09/26/22 10:22 AM
09/26/22 10:22 AM
Correct.
Would a picture help? Ive got 3, nothing into the intake ports though
Re: Indy SR or INDY-1, how to tell what I have [Re: Moparnut426] #3080774
09/26/22 10:26 AM
09/26/22 10:26 AM
heres some pics
Re: Indy SR or INDY-1, how to tell what I have [Re: Moparnut426] #3080783
09/26/22 11:03 AM
09/26/22 11:03 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Those look like -1's because there is no pushrod clearance in the side of the intake port. They need an offset rocker, you cannot use a normal rocker on the -1 intake side.
Re: Indy SR or INDY-1, how to tell what I have [Re: sixpakdodge] #3080785
09/26/22 11:12 AM
09/26/22 11:12 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
For sure 440-1 heads.
69 GTX 68 Road Runner
Re: Indy SR or INDY-1, how to tell what I have [Re: JERICOGTX] #3080790
09/26/22 11:20 AM
09/26/22 11:20 AM
Thanks guys!!
Ill get the expensive rockers coming LOL
Do I go ahead and use the "indy" specific head studs also then? Mancini shows 2 different ones I assume the deck is thicker on a -1
Re: Indy SR or INDY-1, how to tell what I have [Re: Moparnut426] #3080809
09/26/22 12:11 PM
09/26/22 12:11 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Thanks guys!!
The 572-13, and 600-13 heads use taller studs. The 440-1's and SR, use the same set, and are taller than stock type heads.
Re: Indy SR or INDY-1, how to tell what I have [Re: JERICOGTX] #3080846
09/26/22 02:29 PM
09/26/22 02:29 PM
thanks
Re: Indy SR or INDY-1, how to tell what I have [Re: Moparnut426] #3080857
09/26/22 03:03 PM
09/26/22 03:03 PM
The SR heads intake ports narrow down around the pushrod pinch area like the stock M.W .heaads do, the 440-1 don't scope up
I think some of the early SR heads had 440 cast on the rocker arm pedestal on one end or the other and the 440-1 had that cast into them in the same place, maybe not confused
Re: Indy SR or INDY-1, how to tell what I have [Re: Cab_Burge] #3080872
09/26/22 03:34 PM
09/26/22 03:34 PM
NC
440Jim Offline
440Jim  Offline
NC
This pic is an older 440-1 head, but the locations are the same.
The 440-SR will have a pushrod hole machined in the side of the port casting (yellow circle). So the inside of the port can't be as wide at that location.
The 440-1 will have the pushrod go outside the port casting (blue circle).
Re: Indy SR or INDY-1, how to tell what I have [Re: 440Jim] #3080918
09/26/22 06:30 PM
09/26/22 06:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
See anything like this ... on the intake mounting surface
Re: Indy SR or INDY-1, how to tell what I have [Re: Stanton] #3080961
09/26/22 08:26 PM
09/26/22 08:26 PM
NC
440Jim Offline
440Jim  Offline
NC
I found this old pic I have.
It is an Indy 440-SR and you can see the Indy pushrod hole machined in the side of the port casting.
