Hardened rocker shafts for BB #3078951
09/20/22 07:16 AM
09/20/22 07:16 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I need several sets of hardened rockers shafts for some customers. I will be using them on isky iron rockers so I would prefer them to have the grooves like TA rockers have. Anyone know of a supplier for those?
Re: Hardened rocker shafts for BB [Re: fastmark] #3078979
09/20/22 10:22 AM
09/20/22 10:22 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Hardened rocker shafts for BB [Re: fastmark] #3079086
09/20/22 04:54 PM
09/20/22 04:54 PM
Minn
SportF Offline
SportF  Offline
Minn
Stanke Motorsports
https://stankemotorsports.com/index.cfm
He makes them in house, and supplies a lot of engine builders
Re: Hardened rocker shafts for BB [Re: SportF] #3079213
09/21/22 06:46 AM
09/21/22 06:46 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Sounds like what I need guys thanks.
Re: Hardened rocker shafts for BB [Re: fastmark] #3079359
09/21/22 04:39 PM
09/21/22 04:39 PM
Out of the State of Confusion
blue_stocker Offline
You might try Gary Patrick at RAS/RAU...
http://www.rockerarms.com/
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Hardened rocker shafts for BB [Re: fastmark] #3079385
09/21/22 06:24 PM
09/21/22 06:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
When you assemble the rockers on the engine, make sure none of the grooves locates between a rocker and a stand: oil pressure leak.
Boffin Emeritus
Re: Hardened rocker shafts for BB [Re: blue_stocker] #3079493
09/22/22 05:18 AM
09/22/22 05:18 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Just talked to them at length about rebuilding a set of Isky rockers. He has not made any in awhile from Mopars because he’s too busy and material is hard to find. He recommended Stanke.
Re: Hardened rocker shafts for BB [Re: fastmark] #3079627
09/22/22 01:11 PM
09/22/22 01:11 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Interesting, but not surprising considering the current state of things.
FWIW, my RAS shafts are the nicest shafts I've had; I just keep giving them a touch-up polish and reusing 'em. The only other shafts that look as thick-walled to me are the Harland Sharp shafts.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
