Re: Hardened rocker shafts for BB
[Re: fastmark]
#3079385
09/21/22 06:24 PM
09/21/22 06:24 PM
Posts: 4,213 New York
polyspheric
New York
When you assemble the rockers on the engine, make sure none of the grooves locates between a rocker and a stand: oil pressure leak.
Boffin Emeritus
[Re: fastmark]
#3079627
09/22/22 01:11 PM
09/22/22 01:11 PM
Posts: 1,190 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Interesting, but not surprising considering the current state of things.
FWIW, my RAS shafts are the nicest shafts I've had; I just keep giving them a touch-up polish and reusing 'em. The only other shafts that look as thick-walled to me are the Harland Sharp shafts.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
