Re: Arlene Vanke Hemi Intake
[Re: Dragula]
#3063100
07/27/22 06:27 PM
07/27/22 06:27 PM
Posts: 13,675 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
That's the intake that I run on my 540. Ken at Indy had told me that in my street/strip application that I would like the dual plane better than the single. Coming from wedges, honestly, I doubted him. So, I bought both Dominator flanged open and dual plane intakes and ran them back to back on the dyno during break-in. The Vanke dual plane gave up 11hp at the top while picking up nearly 30#lb of torque.
The engine peaks at 6,800 and made 685hp with a 1050.
Master, again and still
[Re: DaveRS23]
#3063115
07/27/22 07:15 PM
07/27/22 07:15 PM
Posts: 3,286 Michigan
A727Tflite
The engine peaks at 6,800 and made 685hp with a 1050. What manifolds are you talking about when you say single plane and dual plane.
[Re: Dragula]
#3063122
07/27/22 08:03 PM
07/27/22 08:03 PM
Posts: 12,582 Taxes & Virus's R-US, NY
Dragula
i have the tall big runner single plane that is all ported out....Makes around 840hp currently. I don't rev it past 6500, so I was wondering if I should swap to the dual plane and try it. Maybe even mill down the divider and port it out and run an open spacer. Did that on a small block eddy air gap and it made a fantastic difference.
PS It does not fit with the air cleaner and the hood down all the way. I even milled a little off the top of that intake and there just isn't room.
Is yours ported, and did you use a phenolic spacer?
[Re: A727Tflite]
#3063231
07/28/22 09:42 AM
07/28/22 09:42 AM
DaveRS23
Benton, IL.
Both intakes were Indys. The combo was going under the Shaker in the Cuda, so height was a major limitation. I also had a Ray Barton intake, but there was no way it was going to fit, so I didn't even run it on the dyno. The open intake was the shorter Indy. I don't remember the number. No room for any spacer. MCH ported the heads, but the intake was uncut. I had a lot of people tell me that any Indy with a Dominator would not fit under the Shaker. Had to lower the K, and had to fab up the Shaker base with a Dominator drop base and build an air cleaner lid out of fiberglass to get the carb up into the bonnet. It all fits.....just barely and was a lot of work. These pics are from the wedge days, but are pretty much the same as today with the Hemi. ![[Linked Image]](https://i.postimg.cc/YCT7H0kL/2009-05-20-16-55-47.jpg) how do i print screen![[Linked Image]](https://i.postimg.cc/P5KQ0vjT/2009-05-20-16-59-17.jpg)
[Re: DaveRS23]
#3063442
07/28/22 08:06 PM
07/28/22 08:06 PM
Posts: 7,667 Minnesota
Hemi_Joel
Minnesota
Before I watched the video, I thought you were talking about the street Hemi factory intake that has the Arlen Vanke modification.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3063449
07/28/22 08:39 PM
07/28/22 08:39 PM
A727Tflite
Before I watched the video, I thought you were talking about the street Hemi factory intake that has the Arlen Vanke modification. Me too, that’s why I asked what manifolds he referred too.
[Re: Hemi_Joel]
#3063451
07/28/22 08:43 PM
07/28/22 08:43 PM
Posts: 9,052 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
Before I watched the video, I thought you were talking about the street Hemi factory intake that has the Arlen Vanke modification. Me too, am thinking of making one
[Re: Cab_Burge]
#3063541
07/29/22 09:59 AM
07/29/22 09:59 AM
Posts: 4,755 Motor City
6PKRTSE
Motor City
I ran my own machined Vanke style street Hemi intake on my other +.030 over mild Hemi on the street. It loved it. Never had any issues.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: DaveRS23]
#3063542
07/29/22 10:03 AM
07/29/22 10:03 AM
6PKRTSE
Motor City
Both intakes were Indys. The combo was going under the Shaker in the Cuda, so height was a major limitation. I also had a Ray Barton intake, but there was no way it was going to fit, so I didn't even run it on the dyno. The open intake was the shorter Indy. I don't remember the number. No room for any spacer. MCH ported the heads, but the intake was uncut. I had a lot of people tell me that any Indy with a Dominator would not fit under the Shaker. Had to lower the K, and had to fab up the Shaker base with a Dominator drop base and build an air cleaner lid out of fiberglass to get the carb up into the bonnet. It all fits.....just barely and was a lot of work. These pics are from the wedge days, but are pretty much the same as today with the Hemi. ![[Linked Image]](https://i.postimg.cc/YCT7H0kL/2009-05-20-16-55-47.jpg) how do i print screen I like your modified base to the side Dominator carb shaker. I modified mine for dual Dominator's and a tunnel ram.
[Re: 6PKRTSE]
#3063702
07/29/22 05:11 PM
07/29/22 05:11 PM
DaveRS23
Benton, IL.
There is nothing complicated about the Vanke mod. My intake also has the splash shield under it but I don't remember if it was part of the Vanke mod or a separate option.
