Arlene Vanke Hemi Intake #3063095
07/27/22 07:13 PM
07/27/22 07:13 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Anyone run one? Thinking of going to one over my single plane....
https://www.youtube.com/watch?v=n89dCwJqbhE
Re: Arlene Vanke Hemi Intake [Re: Dragula] #3063100
07/27/22 07:27 PM
07/27/22 07:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
That's the intake that I run on my 540. Ken at Indy had told me that in my street/strip application that I would like the dual plane better than the single. Coming from wedges, honestly, I doubted him. So, I bought both Dominator flanged open and dual plane intakes and ran them back to back on the dyno during break-in. The Vanke dual plane gave up 11hp at the top while picking up nearly 30#lb of torque.
The engine peaks at 6,800 and made 685hp with a 1050.
Master, again and still
Re: Arlene Vanke Hemi Intake [Re: DaveRS23] #3063115
07/27/22 08:15 PM
07/27/22 08:15 PM
A727Tflite Offline
A727Tflite  Offline
What manifolds are you talking about when you say single plane and dual plane.
Re: Arlene Vanke Hemi Intake [Re: Dragula] #3063122
07/27/22 09:03 PM
07/27/22 09:03 PM
Dragula Offline OP
Dragula  Offline OP
i have the tall big runner single plane that is all ported out....Makes around 840hp currently. I don't rev it past 6500, so I was wondering if I should swap to the dual plane and try it. Maybe even mill down the divider and port it out and run an open spacer. Did that on a small block eddy air gap and it made a fantastic difference.
PS It does not fit with the air cleaner and the hood down all the way. I even milled a little off the top of that intake and there just isn't room.
Is yours ported, and did you use a phenolic spacer?
Re: Arlene Vanke Hemi Intake [Re: A727Tflite] #3063231
07/28/22 10:42 AM
07/28/22 10:42 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Both intakes were Indys. The combo was going under the Shaker in the Cuda, so height was a major limitation. I also had a Ray Barton intake, but there was no way it was going to fit, so I didn't even run it on the dyno. The open intake was the shorter Indy. I don't remember the number. No room for any spacer. MCH ported the heads, but the intake was uncut.
I had a lot of people tell me that any Indy with a Dominator would not fit under the Shaker. Had to lower the K, and had to fab up the Shaker base with a Dominator drop base and build an air cleaner lid out of fiberglass to get the carb up into the bonnet. It all fits.....just barely and was a lot of work. These pics are from the wedge days, but are pretty much the same as today with the Hemi.
[Linked Image]how do i print screen
Re: Arlene Vanke Hemi Intake [Re: DaveRS23] #3063442
07/28/22 09:06 PM
07/28/22 09:06 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Before I watched the video, I thought you were talking about the street Hemi factory intake that has the Arlen Vanke modification.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Arlene Vanke Hemi Intake [Re: Hemi_Joel] #3063449
07/28/22 09:39 PM
07/28/22 09:39 PM
A727Tflite Offline
A727Tflite  Offline
Me too, that’s why I asked what manifolds he referred too.
Re: Arlene Vanke Hemi Intake [Re: Hemi_Joel] #3063451
07/28/22 09:43 PM
07/28/22 09:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Me too, am thinking of making one
Re: Arlene Vanke Hemi Intake [Re: Dragula] #3063461
07/28/22 10:14 PM
07/28/22 10:14 PM
Mopar had that style of magnesium single 4150 carb intakes on the 1964 and 1965 race Hemi 410 HP for NASCAR racing scope
A friend of mine ended up with two of them and was planning on racing a 1964 Plymouth Savoy in NHRA stock but he never got it finish, I don't think he could find the correct carb whineyshruggy
Re: Arlene Vanke Hemi Intake [Re: Cab_Burge] #3063541
07/29/22 10:59 AM
07/29/22 10:59 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I ran my own machined Vanke style street Hemi intake on my other +.030 over mild Hemi on the street. It loved it. Never had any issues.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Arlene Vanke Hemi Intake [Re: DaveRS23] #3063542
07/29/22 11:03 AM
07/29/22 11:03 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I like your modified base to the side Dominator carb shaker. I modified mine for dual Dominator's and a tunnel ram.
Re: Arlene Vanke Hemi Intake [Re: 6PKRTSE] #3063545
07/29/22 11:04 AM
07/29/22 11:04 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
More.
Re: Arlene Vanke Hemi Intake [Re: 6PKRTSE] #3063548
07/29/22 11:05 AM
07/29/22 11:05 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Last one.
Re: Arlene Vanke Hemi Intake [Re: 6PKRTSE] #3063701
07/29/22 06:08 PM
07/29/22 06:08 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You are obviously a MUCH better fabricator than I am. bow
Re: Arlene Vanke Hemi Intake [Re: 6PKRTSE] #3063702
07/29/22 06:11 PM
07/29/22 06:11 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
There is nothing complicated about the Vanke mod. My intake also has the splash shield under it but I don't remember if it was part of the Vanke mod or a separate option.
