Re: Water pump and housing sealant
[Re: 6PAX]
#3061307
07/21/22 12:27 PM
07/21/22 12:27 PM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
None if it we're mine. if anything I would use Hi-tack or Indian head shellac,
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 6PAX]
#3061335
07/21/22 01:16 PM
07/21/22 01:16 PM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
Everyone has their favorite. I use a light coat of ultra grey silicone on the gasket. If using a motorplate, I don't use gaskets at all. Just a light coat of ultra grey silicone.
[Re: an8sec70cuda]
#3061364
07/21/22 02:24 PM
07/21/22 02:24 PM
Posts: 10,022 MN
JERICOGTX
MN
I use Superformance Gaskets, and just install them dry.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3061369
07/21/22 02:32 PM
07/21/22 02:32 PM
Posts: 2,498 PA
moparacer
PA
Been using ultra grey for years between the pump, motor plate and block.
The ultra black would be just as good.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Cab_Burge]
#3061502
07/21/22 08:26 PM
07/21/22 08:26 PM
Posts: 5,439 So Cal
Sinitro
So Cal
1 suggestion... Get some longer threaded studs or cut off the nut head from screws.. Then screw these into the block when installing the water pump housing and seal they act as guides.. Makes the job much easier without having the gasket slip down. Then 1 by 1 unscrew the studs and install the proper bolts and torque things down.. Just my $0.02...
[Re: Sinitro]
#3061514
07/21/22 09:06 PM
07/21/22 09:06 PM
RapidRobert
1 suggestion... Get some longer threaded studs or cut off the nut head from screws.. Then screw these into the block when installing the water pump housing and seal they act as guides.. Makes the job much easier without having the gasket slip down. Then 1 by 1 unscrew the studs and install the proper bolts and torque things down.. Just my $0.02... I totally agree, I do this on other areas including the heads
[Re: 6PAX]
#3061525
07/21/22 10:24 PM
07/21/22 10:24 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Oil or Anti seize up: All the BB Mopar bolt holes for the timing cover and water pump housing mounting bolt holes in the block are blind, they do not go into the water jackets: scope:
[Re: 6PAX]
#3061529
07/21/22 10:43 PM
07/21/22 10:43 PM
Posts: 31,021 Oregon
AndyF
I'm using Fel Pro gaskets. I also meant to ask, should I put anything on the bolt threads? I use ARP 12 point stainless for all builds and put a thin coat of ARP bolt lube on the threads. ARP stainless are the only bolts I use unless the application requires something specific such as rod bolts.
