Water pump and housing sealant #3061237
07/21/22 08:51 AM
07/21/22 08:51 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm about to install my aluminum water pump and housing on my engine. I have a tube of Permatex Form-a-gasket #2 and a tube of Permatex Ultra black. Are either of these ok to use on the gaskets? It's been so long since I installed a water pump that I don't remember what I used the last time.
Re: Water pump and housing sealant [Re: 6PAX] #3061307
07/21/22 12:27 PM
07/21/22 12:27 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
None if it we're mine. if anything I would use Hi-tack or Indian head shellac, twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Water pump and housing sealant [Re: 6PAX] #3061335
07/21/22 01:16 PM
07/21/22 01:16 PM
an8sec70cuda Offline
Everyone has their favorite. I use a light coat of ultra grey silicone on the gasket.
If using a motorplate, I don't use gaskets at all. Just a light coat of ultra grey silicone. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Water pump and housing sealant [Re: an8sec70cuda] #3061364
07/21/22 02:24 PM
07/21/22 02:24 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I use Superformance Gaskets, and just install them dry.
69 GTX 68 Road Runner
Re: Water pump and housing sealant [Re: JERICOGTX] #3061369
07/21/22 02:32 PM
07/21/22 02:32 PM
PA
moparacer Offline
moparacer  Offline
PA
Been using ultra grey for years between the pump, motor plate and block.
The ultra black would be just as good.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Water pump and housing sealant [Re: moparacer] #3061374
07/21/22 02:40 PM
07/21/22 02:40 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Permatex makes an antifreeze specific sealer you can use.
Re: Water pump and housing sealant [Re: 6PAX] #3061381
07/21/22 02:47 PM
07/21/22 02:47 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
Re: Water pump and housing sealant [Re: Neil] #3061471
07/21/22 06:09 PM
07/21/22 06:09 PM
iagree up
Their part # is 22071, works good up, last a long time scope I use it on the gasket (both sides) on the thermostat housing only, not on the water pump to block gaskets twocentswrench
Re: Water pump and housing sealant [Re: Cab_Burge] #3061502
07/21/22 08:26 PM
07/21/22 08:26 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
1 suggestion...
Get some longer threaded studs or cut off the nut head from screws..
Then screw these into the block when installing the water pump housing and seal they act as guides.. Makes the job much easier without having the gasket slip down.
Then 1 by 1 unscrew the studs and install the proper bolts and torque things down..
Just my $0.02... wink
Re: Water pump and housing sealant [Re: Sinitro] #3061506
07/21/22 08:43 PM
07/21/22 08:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use Ultra Grey on everything. My race car motor plate and water pump use it w/o gaskets. Never a leak.
Doug
Re: Water pump and housing sealant [Re: 6PAX] #3061508
07/21/22 08:55 PM
07/21/22 08:55 PM
AndyF Offline
AndyF  Offline
I use the pink gaskets from Superformance and I don't use any sealant.
Re: Water pump and housing sealant [Re: AndyF] #3061512
07/21/22 09:00 PM
07/21/22 09:00 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I'm using Fel Pro gaskets. I also meant to ask, should I put anything on the bolt threads?
Re: Water pump and housing sealant [Re: Sinitro] #3061514
07/21/22 09:06 PM
07/21/22 09:06 PM
Originally Posted by Sinitro
1 suggestion...
I totally agree, I do this on other areas including the heads
Re: Water pump and housing sealant [Re: 6PAX] #3061525
07/21/22 10:24 PM
07/21/22 10:24 PM
Oil or Anti seize up:
All the BB Mopar bolt holes for the timing cover and water pump housing mounting bolt holes in the block are blind, they do not go into the water jackets: scope:
Re: Water pump and housing sealant [Re: 6PAX] #3061529
07/21/22 10:43 PM
07/21/22 10:43 PM
AndyF Offline
AndyF  Offline
I use ARP 12 point stainless for all builds and put a thin coat of ARP bolt lube on the threads. ARP stainless are the only bolts I use unless the application requires something specific such as rod bolts.
