Carrier Runout #3060719
07/19/22 09:28 PM
07/19/22 09:28 PM
Bloomingdale , OH
super451b Offline OP
Bloomingdale , OH
Im setting up a 9.25 for a friend. Its for a 2018 Ram 1500. What would you consider to be excessive runout on the carrier ? (No Gear installed ) The carrier in question is a new truetrac locker.
Re: Carrier Runout [Re: super451b] #3060738
07/19/22 11:03 PM
07/19/22 11:03 PM
I would look at the factory service manual and follow the specs. it provide.
I think the 8 3/4 uses .0030 maximum run out.
I found out by accident that heating the ring gear up to or over 130F and then install it on the carrier really helps making it seat flush eliminating any ring gear to pinion tooth backlash variances up :: scope:
Re: Carrier Runout [Re: Cab_Burge] #3060748
07/19/22 11:48 PM
07/19/22 11:48 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Couple thou, tops. I don't even like to see that.
We deburr everything before putting it together. Stuff has been cheapened, Processes streamlined. Edges and bolt holes will have burrs.
Re: Carrier Runout [Re: CMcAllister] #3060759
07/20/22 12:53 AM
07/20/22 12:53 AM
Bloomingdale , OH
Bloomingdale , OH
I'm checking the carrier without the ring gear attached and I'm getting .003 runout. I was leaning toward having him send it back. Didnt want to go through attaching the gear and trying to get correct backlash if it was going to be a waste of time.
Re: Carrier Runout [Re: super451b] #3060868
07/20/22 10:40 AM
07/20/22 10:40 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might want to call the MFR. and ask what their spec is wink
Re: Carrier Runout [Re: TJP] #3060962
07/20/22 02:27 PM
07/20/22 02:27 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Backlash will effect the pattern some, not as much as pinion depth. Always a good idea to check BL at multiple spots.
Re: Carrier Runout [Re: super451b] #3060979
07/20/22 02:54 PM
07/20/22 02:54 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
I assume you have the correct side bearing preload and the caps torqued?
Re: Carrier Runout [Re: super451b] #3060985
07/20/22 03:02 PM
07/20/22 03:02 PM
N
N
I had a 69 fsm sitting here and the 8 1/4 and 9 3/4 both said maximum run out .006. The 9 1/4 was not born yet but I would assume it would be similar.
Re: Carrier Runout [Re: NITROUSN] #3061003
07/20/22 03:47 PM
07/20/22 03:47 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave The 1970 FSM shows .006 Max . Put it together , and then check it . I've had carrier runout before , and after Torquing the massive Ring Gear on , to pull Specs down to the Low side .. shruggy Try it , can't hurt . drive Ronnie
Re: Carrier Runout [Re: 1969ronnie] #3061079
07/20/22 08:30 PM
07/20/22 08:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Chuck it in the lathe and true it up..
Re: Carrier Runout [Re: cudaman1969] #3061088
07/20/22 08:45 PM
07/20/22 08:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have a local guy "true-up" all the Power-Loc 8 3/4 carriers for my customers. For some reason most of them are out by .010 -.015 shruggy Maybe lots of gear swaps.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Carrier Runout [Re: fourgearsavoy] #3061098
07/20/22 09:13 PM
07/20/22 09:13 PM
Kirkland, Washington
Pacnorthcuda Offline
Gus beer
I’ve worked on many, I don’t believe 10-15 thousands for a second. They would bind up big time at normal backlash…….hogwash.
Re: Carrier Runout [Re: 1969ronnie] #3061162
07/21/22 02:55 AM
07/21/22 02:55 AM
Bloomingdale , OH
Bloomingdale , OH
After bolting on the ring gear the run out came down to .002 . The backlash only varied by .002 as well . I'm happy with that.
Re: Carrier Runout [Re: super451b] #3061311
07/21/22 12:32 PM
07/21/22 12:32 PM
Are you SURE you want to run those gears that tight on the back lash?
I wouldn't tsk
What do the instruction call for on the minimum? I wouldn't run the back lash any tighter than what the manufacturer calls for at room temps. twocents
As already pointed out check the back lash in several different locations, I try to check them 90 degrees apart scope up wrench
Re: Carrier Runout [Re: Cab_Burge] #3061535
07/21/22 11:30 PM
07/21/22 11:30 PM
Bloomingdale , OH
Bloomingdale , OH
.002 is the variance. Actual backlash is .007 - .009
Re: Carrier Runout [Re: super451b] #3061546
07/22/22 03:12 AM
07/22/22 03:12 AM
