Re: Carrier Runout
[Re: super451b]
#3060738
07/19/22 11:03 PM
07/19/22 11:03 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
I would look at the factory service manual and follow the specs. it provide. I think the 8 3/4 uses .0030 maximum run out. I found out by accident that heating the ring gear up to or over 130F and then install it on the carrier really helps making it seat flush eliminating any ring gear to pinion tooth backlash variances :: scope:
Re: Carrier Runout
[Re: Cab_Burge]
#3060748
07/19/22 11:48 PM
07/19/22 11:48 PM
Posts: 11,557 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Couple thou, tops. I don't even like to see that.
We deburr everything before putting it together. Stuff has been cheapened, Processes streamlined. Edges and bolt holes will have burrs.
Re: Carrier Runout
[Re: TJP]
#3060962
07/20/22 02:27 PM
07/20/22 02:27 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Backlash will effect the pattern some, not as much as pinion depth. Always a good idea to check BL at multiple spots.
Re: Carrier Runout
[Re: super451b]
#3060979
07/20/22 02:54 PM
07/20/22 02:54 PM
Posts: 18,417 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I'm checking the carrier without the ring gear attached and I'm getting .003 runout. I was leaning toward having him send it back. Didnt want to go through attaching the gear and trying to get correct backlash if it was going to be a waste of time. I assume you have the correct side bearing preload and the caps torqued?
Re: Carrier Runout
[Re: cudaman1969]
#3061088
07/20/22 08:45 PM
07/20/22 08:45 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Chuck it in the lathe and true it up.. I have a local guy "true-up" all the Power-Loc 8 3/4 carriers for my customers. For some reason most of them are out by .010 -.015 Maybe lots of gear swaps. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Carrier Runout
[Re: fourgearsavoy]
#3061098
07/20/22 09:13 PM
07/20/22 09:13 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
Chuck it in the lathe and true it up.. I have a local guy "true-up" all the Power-Loc 8 3/4 carriers for my customers. For some reason most of them are out by .010 -.015 Maybe lots of gear swaps. Gus I’ve worked on many, I don’t believe 10-15 thousands for a second. They would bind up big time at normal backlash…….hogwash.
