2 piece BB valve covers?
#3007648
01/21/22 05:23 PM
01/21/22 05:23 PM
Posts: 8,639 Buford, GA
I_bleed_MOPAR
Buford, GA
Anyone know of a set of that will work for adjustable rockers? It's such a pain to r&r the covers then lean over the fenders again to run the valves. And I'm not getting any younger.  Search here turned up nothing as far as being adjustable-friendly to just remove the top part. Any help is appreciated.  Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car  )
Re: 2 piece BB valve covers?
[Re: AndyF]
#3007713
01/21/22 08:53 PM
01/21/22 08:53 PM
I_bleed_MOPAR
Buford, GA
Looks like that would work (minus the clear top  ).  Are these on the market or just one-offs someone made? Tim
[Re: I_bleed_MOPAR]
#3007734
01/21/22 09:59 PM
01/21/22 09:59 PM
Posts: 17,622 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Anyone know of a set of that will work for adjustable rockers? It's such a pain to r&r the covers then lean over the fenders again to run the valves. And I'm not getting any younger.  Search here turned up nothing as far as being adjustable-friendly to just remove the top part. Any help is appreciated.  Tim I do not think having two piece will make it any easier.
[Re: NITROUSN]
#3007792
01/22/22 09:44 AM
01/22/22 09:44 AM
Posts: 8,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I do not think having two piece will make it any easier. I agree. Less messy maybe!
[Re: lancer493]
#3007846
01/22/22 01:20 PM
01/22/22 01:20 PM
Posts: 8,890 Rogue River, OR
Jeremiah
Rogue River, OR
Andi i would love set to have at the dyno down here. Cab and I dyno at the same place so they would get used for sure.
[Re: Jeremiah]
#3007930
01/22/22 05:28 PM
01/22/22 05:28 PM
Posts: 29,651 Oregon
AndyF
I built two of them and we only use one so I could sell one cover. They were expensive to build so you might not want to hear the price but if you're interested shoot me a PM. Here is a link to a video showing the cover in operation during a dyno pull. Once the engine hits 6000 rpm the cover fills up with oil. https://www.youtube.com/watch?v=8oLyIhDdKww
[Re: AndyF]
#3007941
01/22/22 05:53 PM
01/22/22 05:53 PM
Posts: 22,664 Rio Linda, CA
John_Kunkel
Much ado about nothing
Rio Linda, CA
What material is used for the transparent panel? Plexiglass? Lexan? How does it stand up to the heat?
Doing my best to irritate the herd.
[Re: AndyF]
#3007943
01/22/22 05:57 PM
01/22/22 05:57 PM
Posts: 267 Mountain View, CA
68rrunner
Mountain View, CA
I built two of them and we only use one so I could sell one cover. They were expensive to build so you might not want to hear the price but if you're interested shoot me a PM. Here is a link to a video showing the cover in operation during a dyno pull. Once the engine hits 6000 rpm the cover fills up with oil. https://www.youtube.com/watch?v=8oLyIhDdKww Filled with oil or just so much splash that the view became obscured? Had me concerned about the oil being able to drain back in a road racing situation.
[Re: John_Kunkel]
#3007945
01/22/22 06:03 PM
01/22/22 06:03 PM
AndyF
What material is used for the transparent panel? Plexiglass? Lexan? How does it stand up to the heat? I used Lexan. It has a melting point of 500 degrees so it isn't really bothered by 180 degree oil. I assume that the Lexan would fail in an OEM environment but we just use these covers for dyno engines so they only get an hour of use maybe once a month.
[Re: Stanton]
#3008117
01/23/22 11:45 AM
01/23/22 11:45 AM
I_bleed_MOPAR
Buford, GA
I do not think having two piece will make it any easier. I agree. Less messy maybe! My thinking was that it would be a little easier to R&R the top cover than to R&R the whole valve cover. If no one has any real-world experience (other than Andy), maybe I'll switch to studs & nuts for the covers with a dab of adhesive to hold the gasket in place. Thanks, Tim
[Re: fourgearsavoy]
#3008233
01/23/22 04:04 PM
01/23/22 04:04 PM
I_bleed_MOPAR
Buford, GA
I glue my gaskets to the covers with 3M trim adhesive and use long set screws for studs and flanged nuts on my engine. Works great and stays clean  Gus  Tim
[Re: I_bleed_MOPAR]
#3008242
01/23/22 04:36 PM
01/23/22 04:36 PM
AndyF
I do not think having two piece will make it any easier. I agree. Less messy maybe! My thinking was that it would be a little easier to R&R the top cover than to R&R the whole valve cover. If no one has any real-world experience (other than Andy), maybe I'll switch to studs & nuts for the covers with a dab of adhesive to hold the gasket in place. Thanks, Tim In my experience the best setup is a set of rigid valve covers with a very thick, very rigid rail. Use them with an aftermarket aluminum head with a machined valve cover rail and then use the Cometic rubber/steel core gasket. That combination is leak proof and you never need to replace the gasket. Just wipe it clean and reuse it over and over. I build my own valve covers since nobody used to sell one that I liked but the new Trick Flow valve cover is pretty good.
