2 piece BB valve covers? #3007648
01/21/22 05:23 PM
01/21/22 05:23 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Anyone know of a set of that will work for adjustable rockers? It's such a pain to r&r the covers then lean over the fenders again to run the valves. And I'm not getting any younger. blush
Search here turned up nothing as far as being adjustable-friendly to just remove the top part. Any help is appreciated. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2 piece BB valve covers? [Re: I_bleed_MOPAR] #3007688
01/21/22 07:31 PM
01/21/22 07:31 PM
AndyF Offline
AndyF  Offline
Something like this?
Re: 2 piece BB valve covers? [Re: AndyF] #3007691
01/21/22 07:42 PM
01/21/22 07:42 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Those are beautiful. I wish they had an AR part number!
Re: 2 piece BB valve covers? [Re: Jeremiah] #3007711
01/21/22 08:49 PM
01/21/22 08:49 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 2 piece BB valve covers? [Re: AndyF] #3007713
01/21/22 08:53 PM
01/21/22 08:53 PM
Buford, GA
Buford, GA
Looks like that would work (minus the clear top wink ). up
Are these on the market or just one-offs someone made?
Tim
'71 Charger 383/727
Re: 2 piece BB valve covers? [Re: I_bleed_MOPAR] #3007720
01/21/22 09:10 PM
01/21/22 09:10 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Let's guess who made them??????
They would be a seller, What do you think Andy? Any chance//
Joe
Re: 2 piece BB valve covers? [Re: I_bleed_MOPAR] #3007734
01/21/22 09:59 PM
01/21/22 09:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Tim
I do not think having two piece will make it any easier.
Re: 2 piece BB valve covers? [Re: NITROUSN] #3007792
01/22/22 09:44 AM
01/22/22 09:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
I agree. Less messy maybe!
Re: 2 piece BB valve covers? [Re: Stanton] #3007802
01/22/22 10:42 AM
01/22/22 10:42 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I too agree,it maybe less messy to adjust rockers. Also would aid fresh start-ups, oiling valve springs and pre oiling pushrod, valve and rocker tips. May offer visual on oil drainback and oil spray characteristics. Andy could probably rate the last part based on his experience of the visibility quality available. Aluminum tops could be substituted for continued use if the were less expensive and more durable. The clear top could be available as an optional piece for inspection purposes. The real problem is the same as aftermarket blocks presents. Less BBM engines being built. Production costs/sales may be cost prohibitve for manufacturing. Now if you're a builder of multiple BBM engines and combinations of this engine, there is no denying the value of this helpful tool. As a side note, it sort of helps make the case for hydralic roller cams for anything but all-out combos. Extremely nice product and workmanship on Andy's covers! Bill
Re: 2 piece BB valve covers? [Re: lancer493] #3007805
01/22/22 11:06 AM
01/22/22 11:06 AM
AndyF Offline
AndyF  Offline
They work great on the dyno. Allow us to see the oil spray as well as the operation of the valvetrain.
https://www.youtube.com/watch?v=Hlw70nAao38
Re: 2 piece BB valve covers? [Re: AndyF] #3007807
01/22/22 11:15 AM
01/22/22 11:15 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Thanks Andy for the link to that video. The visibility with your valve covers is incredible. What a great tool. Great job! Bill
Re: 2 piece BB valve covers? [Re: lancer493] #3007846
01/22/22 01:20 PM
01/22/22 01:20 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Andi i would love set to have at the dyno down here. Cab and I dyno at the same place so they would get used for sure.
Re: 2 piece BB valve covers? [Re: Jeremiah] #3007930
01/22/22 05:28 PM
01/22/22 05:28 PM
AndyF Offline
AndyF  Offline
I built two of them and we only use one so I could sell one cover. They were expensive to build so you might not want to hear the price but if you're interested shoot me a PM.
Here is a link to a video showing the cover in operation during a dyno pull. Once the engine hits 6000 rpm the cover fills up with oil.
https://www.youtube.com/watch?v=8oLyIhDdKww
Re: 2 piece BB valve covers? [Re: AndyF] #3007941
01/22/22 05:53 PM
01/22/22 05:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What material is used for the transparent panel? Plexiglass? Lexan? How does it stand up to the heat?
Re: 2 piece BB valve covers? [Re: AndyF] #3007943
01/22/22 05:57 PM
01/22/22 05:57 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Filled with oil or just so much splash that the view became obscured?
Had me concerned about the oil being able to drain back in a road racing situation.
Re: 2 piece BB valve covers? [Re: John_Kunkel] #3007945
01/22/22 06:03 PM
01/22/22 06:03 PM
AndyF Offline
AndyF  Offline
I used Lexan. It has a melting point of 500 degrees so it isn't really bothered by 180 degree oil. I assume that the Lexan would fail in an OEM environment but we just use these covers for dyno engines so they only get an hour of use maybe once a month.
Re: 2 piece BB valve covers? [Re: Stanton] #3008117
01/23/22 11:45 AM
01/23/22 11:45 AM
Buford, GA
Buford, GA
Originally Posted by Stanton
Quote
My thinking was that it would be a little easier to R&R the top cover than to R&R the whole valve cover.
If no one has any real-world experience (other than Andy), maybe I'll switch to studs & nuts for the covers with a dab of adhesive to hold the gasket in place.
Thanks,
Tim
'71 Charger 383/727
Re: 2 piece BB valve covers? [Re: I_bleed_MOPAR] #3008159
01/23/22 01:15 PM
01/23/22 01:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I glue my gaskets to the covers with 3M trim adhesive and use long set screws for studs and flanged nuts on my engine. Works great and stays clean twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 2 piece BB valve covers? [Re: fourgearsavoy] #3008233
01/23/22 04:04 PM
01/23/22 04:04 PM
Buford, GA
Buford, GA
Gus beer
thumbs
Tim
'71 Charger 383/727
Re: 2 piece BB valve covers? [Re: I_bleed_MOPAR] #3008242
01/23/22 04:36 PM
01/23/22 04:36 PM
AndyF Offline
AndyF  Offline
Quote
Thanks,
Tim
In my experience the best setup is a set of rigid valve covers with a very thick, very rigid rail. Use them with an aftermarket aluminum head with a machined valve cover rail and then use the Cometic rubber/steel core gasket. That combination is leak proof and you never need to replace the gasket. Just wipe it clean and reuse it over and over. I build my own valve covers since nobody used to sell one that I liked but the new Trick Flow valve cover is pretty good.
