2 piece BB valve covers?
#3007648
01/21/22 05:23 PM
01/21/22 05:23 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Anyone know of a set of that will work for adjustable rockers? It's such a pain to r&r the covers then lean over the fenders again to run the valves. And I'm not getting any younger. Search here turned up nothing as far as being adjustable-friendly to just remove the top part. Any help is appreciated. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: 2 piece BB valve covers?
[Re: AndyF]
#3007713
01/21/22 08:53 PM
01/21/22 08:53 PM
I_bleed_MOPAR
Buford, GA
Looks like that would work (minus the clear top ). Are these on the market or just one-offs someone made? Tim
[Re: I_bleed_MOPAR]
#3007734
01/21/22 09:59 PM
01/21/22 09:59 PM
Posts: 18,417 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Anyone know of a set of that will work for adjustable rockers? It's such a pain to r&r the covers then lean over the fenders again to run the valves. And I'm not getting any younger. Search here turned up nothing as far as being adjustable-friendly to just remove the top part. Any help is appreciated. Tim I do not think having two piece will make it any easier.
[Re: NITROUSN]
#3007792
01/22/22 09:44 AM
01/22/22 09:44 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I do not think having two piece will make it any easier. I agree. Less messy maybe!
[Re: lancer493]
#3007846
01/22/22 01:20 PM
01/22/22 01:20 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
Andi i would love set to have at the dyno down here. Cab and I dyno at the same place so they would get used for sure.
[Re: Jeremiah]
#3007930
01/22/22 05:28 PM
01/22/22 05:28 PM
Posts: 31,029 Oregon
AndyF
I built two of them and we only use one so I could sell one cover. They were expensive to build so you might not want to hear the price but if you're interested shoot me a PM. Here is a link to a video showing the cover in operation during a dyno pull. Once the engine hits 6000 rpm the cover fills up with oil. https://www.youtube.com/watch?v=8oLyIhDdKww
[Re: AndyF]
#3007941
01/22/22 05:53 PM
01/22/22 05:53 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What material is used for the transparent panel? Plexiglass? Lexan? How does it stand up to the heat?
[Re: AndyF]
#3007943
01/22/22 05:57 PM
01/22/22 05:57 PM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
I built two of them and we only use one so I could sell one cover. They were expensive to build so you might not want to hear the price but if you're interested shoot me a PM. Here is a link to a video showing the cover in operation during a dyno pull. Once the engine hits 6000 rpm the cover fills up with oil. https://www.youtube.com/watch?v=8oLyIhDdKww Filled with oil or just so much splash that the view became obscured? Had me concerned about the oil being able to drain back in a road racing situation.
[Re: John_Kunkel]
#3007945
01/22/22 06:03 PM
01/22/22 06:03 PM
AndyF
What material is used for the transparent panel? Plexiglass? Lexan? How does it stand up to the heat? I used Lexan. It has a melting point of 500 degrees so it isn't really bothered by 180 degree oil. I assume that the Lexan would fail in an OEM environment but we just use these covers for dyno engines so they only get an hour of use maybe once a month.
[Re: Stanton]
#3008117
01/23/22 11:45 AM
01/23/22 11:45 AM
I_bleed_MOPAR
Buford, GA
I do not think having two piece will make it any easier. I agree. Less messy maybe! My thinking was that it would be a little easier to R&R the top cover than to R&R the whole valve cover. If no one has any real-world experience (other than Andy), maybe I'll switch to studs & nuts for the covers with a dab of adhesive to hold the gasket in place. Thanks, Tim
[Re: fourgearsavoy]
#3008233
01/23/22 04:04 PM
01/23/22 04:04 PM
I_bleed_MOPAR
Buford, GA
I glue my gaskets to the covers with 3M trim adhesive and use long set screws for studs and flanged nuts on my engine. Works great and stays clean Gus Tim
[Re: I_bleed_MOPAR]
#3008242
01/23/22 04:36 PM
01/23/22 04:36 PM
AndyF
I do not think having two piece will make it any easier. I agree. Less messy maybe! My thinking was that it would be a little easier to R&R the top cover than to R&R the whole valve cover. If no one has any real-world experience (other than Andy), maybe I'll switch to studs & nuts for the covers with a dab of adhesive to hold the gasket in place. Thanks, Tim In my experience the best setup is a set of rigid valve covers with a very thick, very rigid rail. Use them with an aftermarket aluminum head with a machined valve cover rail and then use the Cometic rubber/steel core gasket. That combination is leak proof and you never need to replace the gasket. Just wipe it clean and reuse it over and over. I build my own valve covers since nobody used to sell one that I liked but the new Trick Flow valve cover is pretty good.
