Re: Getrag trans PREVENTIVE fix ?
[Re: dOrk !]
#2996945
12/20/21 08:59 AM
12/20/21 08:59 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Over filling keeps the input bearing wet and last a lot longer. I put over 300K towing miles on my Getrag 360 with a couple rebuilds. I would fill it up to the fill hole then pull the shifter and add another quart.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: dOrk !]
#2996957
12/20/21 09:19 AM
12/20/21 09:19 AM
moparmarks
How extensive of a rebuild?
Have you heard of that pipe fitting deal ?
Ive never had any experience with this trans at all ... I’m just considering a 93 diesel truck purchase Bearing and ring kit. The first build I had to buy a new input shaft. Yes but I thought it would harder to fill than pulling the shifter.
[Re: dOrk !]
#2997025
12/20/21 12:53 PM
12/20/21 12:53 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I’m just considering a 93 diesel truck purchase With a used truck, any damage is already done; overfilling it now is like closing the barn door after............. My high-mile '92 was on its second Getrag and failed shortly after I bought. Replaced it with a NV4500 which also has known problems.
[Re: John_Kunkel]
#2997032
12/20/21 01:23 PM
12/20/21 01:23 PM
moparmarks
I bought my 92 D350 Cummins with 80K on the clock and it already had a Chrysler rebuilt tranny in it. Had a metal rebuild tag on it and I don't know how many miles were on it. It lasted about another 20K for me and the front bearing and shaft fried.
[Re: dOrk !]
#2997222
12/21/21 03:09 AM
12/21/21 03:09 AM
Posts: 608 TN
1DGEMAN
TN
Getrag nothing but scrap iron. throw it away and put a NV4500 in it.
Real Men shift for themselves
[Re: dOrk !]
#2997297
12/21/21 01:42 PM
12/21/21 01:42 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
These guys for manuals. standard transmission.com out of Texas. Cummins Allison conversions: caconversions.com out of Florida
Carl Kessel
[Re: dOrk !]
#2997376
12/21/21 06:19 PM
12/21/21 06:19 PM
CKessel
Los Osos, Ca
Standard carries what's needed if you change the Getrag to a newer unit, in case you decide to keep your left foot/leg occupied.
Carl Kessel
[Re: CKessel]
#2997390
12/21/21 07:07 PM
12/21/21 07:07 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Standard carries what's needed if you change the Getrag to a newer unit, in case you decide to keep your left foot/leg occupied. Newer unit ? ... that’s bulletproof with good maintenance? Anyone have any overdrive numbers on any of these diesel transmissions ?
[Re: dOrk !]
#2997574
12/22/21 01:08 PM
12/22/21 01:08 PM
CKessel
Los Osos, Ca
The 4500's, 5600's and g56 all have issues to one extent. Standard has remedies for them all and has the updates done on the units they sell. I believe any of them are an improvement over what you have. Depends on how much you want to spend. Of the 6spds, the 5600 is the best with their gear fix. Check out the website. My truck is a 04.5 h/o with the nv5600 in it. Great unit. Run Amsoil in it with the 1-2 qt overfill done through the shift tower.
Carl Kessel
