Getrag trans PREVENTIVE fix ? #2996934
12/20/21 08:17 AM
12/20/21 08:17 AM
Florida STAYcation
BeEtLeJuIcE ! Offline OP
The village idiot's idiot
Florida STAYcation
.... isn’t the problem the trans fluid being too low ?
That the factory fill plug is way low and the level should be raised .....via some pipe fittings ... ???
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2996945
12/20/21 08:59 AM
12/20/21 08:59 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Over filling keeps the input bearing wet and last a lot longer. I put over 300K towing miles on my Getrag 360 with a couple rebuilds.
I would fill it up to the fill hole then pull the shifter and add another quart.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Getrag trans PREVENTIVE fix ? [Re: moparmarks] #2996954
12/20/21 09:12 AM
12/20/21 09:12 AM
Florida STAYcation
Florida STAYcation
How extensive of a rebuild?
Have you heard of that pipe fitting deal ?
Ive never had any experience with this trans at all ... I’m just considering a 93 diesel truck purchase
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2996957
12/20/21 09:19 AM
12/20/21 09:19 AM
moparmarks Offline
moparmarks  Offline
Bearing and ring kit. The first build I had to buy a new input shaft.
Yes but I thought it would harder to fill than pulling the shifter.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Getrag trans PREVENTIVE fix ? [Re: moparmarks] #2997023
12/20/21 12:44 PM
12/20/21 12:44 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I went thru one 20 years ago, he had his truck towed from the rear and it was low on fluid, wiped out the rear shift fork. If you ever have your truck towed pull the driveshaft, keep it full of fluid, and it is a pretty good trans.
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2997025
12/20/21 12:53 PM
12/20/21 12:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With a used truck, any damage is already done; overfilling it now is like closing the barn door after.............
My high-mile '92 was on its second Getrag and failed shortly after I bought. Replaced it with a NV4500 which also has known problems.
Re: Getrag trans PREVENTIVE fix ? [Re: John_Kunkel] #2997032
12/20/21 01:23 PM
12/20/21 01:23 PM
moparmarks Offline
moparmarks  Offline
I bought my 92 D350 Cummins with 80K on the clock and it already had a Chrysler rebuilt tranny in it. Had a metal rebuild tag on it and I don't know how many miles were on it. It lasted about another 20K for me and the front bearing and shaft fried.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Getrag trans PREVENTIVE fix ? [Re: moparmarks] #2997149
12/20/21 09:16 PM
12/20/21 09:16 PM
Florida STAYcation
Florida STAYcation
So guyz ... its just a matter of WHEN you have to do a tranny rebuilt on these earlier stick shifts ?
When did they put in ones that were not destined to fail ?
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2997222
12/21/21 03:09 AM
12/21/21 03:09 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Getrag nothing but scrap iron. throw it away and put a NV4500 in it.
Real Men shift for themselves
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2997228
12/21/21 07:12 AM
12/21/21 07:12 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My brother in law bought a 90 model new. It’s got 180,000 on it now. We serviced the truck about three years ago and we installed a street 90 fitting with the plug installed up. It allows you to install about a 1/2 quart or more fluid. I think it uses Mobil one oil. He’s had no problem since new. The nv4500 has fifth gear problems but they have a fix for that too.
Re: Getrag trans PREVENTIVE fix ? [Re: John_Kunkel] #2997239
12/21/21 09:28 AM
12/21/21 09:28 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Would like to know more about history and progress year by year
of Getrag
MANUAL trans families.
Is there a web link, magazine article or English language forum?
{or German language forum that Google translate magic could tackle}
Re: Getrag trans PREVENTIVE fix ? [Re: 360view] #2997282
12/21/21 12:45 PM
12/21/21 12:45 PM
Florida STAYcation
Florida STAYcation
Day-ummmmm ... so Get and NV pieces are junk ... in the end ?
Anyone ever hear how difficult and expensive a Allison upgrade is ?
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2997297
12/21/21 01:42 PM
12/21/21 01:42 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
These guys for manuals. standard transmission.com out of Texas. Cummins Allison conversions: caconversions.com out of Florida
Carl Kessel
Re: Getrag trans PREVENTIVE fix ? [Re: CKessel] #2997308
12/21/21 01:57 PM
12/21/21 01:57 PM
Florida STAYcation
Florida STAYcation
Thx cK ..... I’m sure larryLOVEit my Allison in my motor homey up
I also belong to a relatively large RV group and I don’t think I’ve ever heard of complaints about the Allison...
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2997376
12/21/21 06:19 PM
12/21/21 06:19 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Standard carries what's needed if you change the Getrag to a newer unit, in case you decide to keep your left foot/leg occupied.
Carl Kessel
Re: Getrag trans PREVENTIVE fix ? [Re: CKessel] #2997390
12/21/21 07:07 PM
12/21/21 07:07 PM
Florida STAYcation
Florida STAYcation
Newer unit ? ... that’s bulletproof with good maintenance?
Anyone have any overdrive numbers on any of these diesel transmissions ?
Re: Getrag trans PREVENTIVE fix ? [Re: BeEtLeJuIcE !] #2997574
12/22/21 01:08 PM
12/22/21 01:08 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
The 4500's, 5600's and g56 all have issues to one extent. Standard has remedies for them all and has the updates done on the units they sell. I believe any of them are an improvement over what you have. Depends on how much you want to spend. Of the 6spds, the 5600 is the best with their gear fix. Check out the website. My truck is a 04.5 h/o with the nv5600 in it. Great unit. Run Amsoil in it with the 1-2 qt overfill done through the shift tower.
Carl Kessel
