Haven’t seen a pcv like this before on 440 #2985413
11/15/21 02:06 PM
11/15/21 02:06 PM
Someplace you aren't
SomeCarGuy Offline OP
I’ve only seen the plastic ones. Even have an original Chrysler one on a 71 440 sitting here. Doesn’t seem to want to pull out either. Has to be homemade, right?
I want my fair share
Re: Haven’t seen a pcv like this before on 440 [Re: SomeCarGuy] #2985414
11/15/21 02:07 PM
11/15/21 02:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
ALL 1969 and earlier (whenever pcv’s started) Mopars
….Need to show some love to the 69 and earlier Mopars more wink
Re: Haven’t seen a pcv like this before on 440 [Re: SomeCarGuy] #2985416
11/15/21 02:08 PM
11/15/21 02:08 PM
No, that is stock before Mopar switch the cheaper plastic ones whiney down
Re: Haven’t seen a pcv like this before on 440 [Re: Cab_Burge] #2985418
11/15/21 02:12 PM
11/15/21 02:12 PM
Ok guess the ones I’ve had were all converted. The rockauto site lists the plastic one for 69.
Re: Haven’t seen a pcv like this before on 440 [Re: SomeCarGuy] #2985451
11/15/21 02:50 PM
11/15/21 02:50 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The threads are for a locknut on the earlier push-on caps before Mopar went to grommets on the VC's.
Re: Haven’t seen a pcv like this before on 440 [Re: 6PakBee] #2985474
11/15/21 04:02 PM
11/15/21 04:02 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
You have to be old enough to remember that type.....
You don't want to fall into my category, I can assure you....
Joe
Re: Haven’t seen a pcv like this before on 440 [Re: 6PakBee] #2985489
11/15/21 04:48 PM
11/15/21 04:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Like so.
Re: Haven’t seen a pcv like this before on 440 [Re: SomeCarGuy] #2985565
11/15/21 08:40 PM
11/15/21 08:40 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I have a 50,000 mile '69 RR and has same.
Re: Haven’t seen a pcv like this before on 440 [Re: Cab_Burge] #2985586
11/15/21 09:41 PM
11/15/21 09:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: Haven’t seen a pcv like this before on 440 [Re: jlatessa] #2985587
11/15/21 09:41 PM
11/15/21 09:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Joe
Re: Haven’t seen a pcv like this before on 440 [Re: TJP] #2985741
11/16/21 12:34 PM
11/16/21 12:34 PM
moparx Online content
moparx  Online Content
Joe
umm.......what was i going to say........ OH yeah ! now i remember ! i agree with the above ! up don't get close to spiders. they will fill your "remember place" with cobwebs when you slow down enough. biggrin
beer
Re: Haven’t seen a pcv like this before on 440 [Re: SomeCarGuy] #2986356
11/18/21 11:02 AM
11/18/21 11:02 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I've got the same thing in one of my spare valve covers (don't remember the year of the engine).
How DO you get it out of the VC? Is it just 'stuck' because the grommet is rock hard, or is it locked in place because of the threaded part? shruggy sawzall
John
Re: Haven’t seen a pcv like this before on 440 [Re: SattyNoCar] #2986364
11/18/21 11:37 AM
11/18/21 11:37 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Rock hard grommet makes them real tough to remove
Re: Haven’t seen a pcv like this before on 440 [Re: SattyNoCar] #2986365
11/18/21 11:46 AM
11/18/21 11:46 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Burn the grommet out with a torch, then scrape it off. EZ/PZ. Even Propane or Mapp Gas. Anything handy.
weld
Rich H.
Esse Quam Videri
Re: Haven’t seen a pcv like this before on 440 [Re: ZIPPY] #2986369
11/18/21 11:54 AM
11/18/21 11:54 AM
A727Tflite Offline
A727Tflite  Offline
weld
Use a heat gun to soften it up.
Re: Haven’t seen a pcv like this before on 440 [Re: A727Tflite] #2986375
11/18/21 12:12 PM
11/18/21 12:12 PM
i would use a heat gun as transman suggests. i have used a torch before, and although it works, it makes a smokey, gooey, stinky mess in the process.
if a heat gun is not available, a box cutter with a new blade [or two] can cut the grommet in several places, freeing up the pvc valve enough to get it out.
beer
Re: Haven’t seen a pcv like this before on 440 [Re: moparx] #2986383
11/18/21 12:25 PM
11/18/21 12:25 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I came up lacking an indoor work space.
Can you tell? smile
Rich H.
Esse Quam Videri
Re: Haven’t seen a pcv like this before on 440 [Re: ZIPPY] #2986420
11/18/21 01:36 PM
11/18/21 01:36 PM
HAHAHAHAHA ! i hardly ever have an indoor work space unless i'm at the lathe, mill, or drill press !
it seems all the VEHICLE work needs done in the driveway. biggrin
i think it is because of my "stuff" collection ! laugh2
beer
Re: Haven’t seen a pcv like this before on 440 [Re: John_Kunkel] #2987488
11/21/21 01:37 PM
11/21/21 01:37 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Still running the one out of my 66 Newport. Flush it out with some spray carb. cleaner and motor on.
Re: Haven’t seen a pcv like this before on 440 [Re: SattyNoCar] #2987548
11/21/21 04:16 PM
11/21/21 04:16 PM
Soak it, the valve cover, in hot water, 160F + and remove it carefully so you don't get burnt scope wrench up
