Haven’t seen a pcv like this before on 440
#2985413
11/15/21 02:06 PM
11/15/21 02:06 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I’ve only seen the plastic ones. Even have an original Chrysler one on a 71 440 sitting here. Doesn’t seem to want to pull out either. Has to be homemade, right?
I want my fair share
Re: Haven’t seen a pcv like this before on 440
[Re: SomeCarGuy]
#2985414
11/15/21 02:07 PM
11/15/21 02:07 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
ALL 1969 and earlier (whenever pcv’s started) Mopars ….Need to show some love to the 69 and earlier Mopars more
[Re: Cab_Burge]
#2985418
11/15/21 02:12 PM
11/15/21 02:12 PM
SomeCarGuy
Ok guess the ones I’ve had were all converted. The rockauto site lists the plastic one for 69.
[Re: SomeCarGuy]
#2985451
11/15/21 02:50 PM
11/15/21 02:50 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
The threads are for a locknut on the earlier push-on caps before Mopar went to grommets on the VC's.
[Re: 6PakBee]
#2985489
11/15/21 04:48 PM
11/15/21 04:48 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The threads are for a locknut on the earlier push-on caps before Mopar went to grommets on the VC's. Like so.
[Re: Cab_Burge]
#2985586
11/15/21 09:41 PM
11/15/21 09:41 PM
Posts: 15,424 Omaha Ne
TJP
Omaha Ne
[Re: SomeCarGuy]
#2986356
11/18/21 11:02 AM
11/18/21 11:02 AM
Posts: 16,828 Between Houston & Galveston TX
SattyNoCar
I’ve only seen the plastic ones. Even have an original Chrysler one on a 71 440 sitting here. Doesn’t seem to want to pull out either. Has to be homemade, right? I've got the same thing in one of my spare valve covers (don't remember the year of the engine). How DO you get it out of the VC? Is it just 'stuck' because the grommet is rock hard, or is it locked in place because of the threaded part?
John
[Re: SattyNoCar]
#2986365
11/18/21 11:46 AM
11/18/21 11:46 AM
Posts: 17,872 S.E. Michigan
ZIPPY
S.E. Michigan
Burn the grommet out with a torch, then scrape it off. EZ/PZ. Even Propane or Mapp Gas. Anything handy.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2986369
11/18/21 11:54 AM
11/18/21 11:54 AM
Posts: 3,087 Michigan
A727Tflite
Burn the grommet out with a torch, then scrape it off. EZ/PZ. Even Propane or Mapp Gas. Anything handy. Use a heat gun to soften it up.
[Re: moparx]
#2986383
11/18/21 12:25 PM
11/18/21 12:25 PM
ZIPPY
S.E. Michigan
I came up lacking an indoor work space. Can you tell?
Rich H.
Esse Quam Videri
[Re: SattyNoCar]
#2987548
11/21/21 04:16 PM
11/21/21 04:16 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I’ve only seen the plastic ones. Even have an original Chrysler one on a 71 440 sitting here. Doesn’t seem to want to pull out either. Has to be homemade, right? I've got the same thing in one of my spare valve covers (don't remember the year of the engine). How DO you get it out of the VC? Is it just 'stuck' because the grommet is rock hard, or is it locked in place because of the threaded part? Soak it, the valve cover, in hot water, 160F + and remove it carefully so you don't get burnt
