1.6 rockers and 440 valve covers #2941792
07/10/21 01:03 PM
07/10/21 01:03 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Generally speaking do 1.6 ratio rockers usually fit under stock 440 valve covers or is it flat out "no never"? Thank you.
Facts are stubborn things.
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2941806
07/10/21 01:59 PM
07/10/21 01:59 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
i have the huges in mine. the baffles needed a small dent put in them where the adjustment nut contacts them .a very small dent l. . stock 440-6 valve covers -71 style
Re: 1.6 rockers and 440 valve covers [Re: ek3] #2941812
07/10/21 02:23 PM
07/10/21 02:23 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Good info thank you! Trying to buy crate engine and many have 1.6's but I need/want stock valve covers because I like and to fit under booster on truck up
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2941857
07/10/21 05:07 PM
07/10/21 05:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
It'll depend on the profile of the rocker, and what year stock valve covers your using, I got Crane 1.6 arms on my 440, using 70 440 stock valve covers, I had to lose the baffles in the cover to clear the arms/adjusters, some applications you can get by using cover spacers, or dimpling the baffles for clearance, or if you have the room, relocate/reweld the baffles closer to the top of the cover....
Re: 1.6 rockers and 440 valve covers [Re: DAYCLONA] #2941881
07/10/21 06:45 PM
07/10/21 06:45 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Okay I'll figure out soon which I'll be using and what year covers I have up
Are those baffles for rigidity? It's hard to imagine what they are accomplishing so close to the top.
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2941896
07/10/21 07:58 PM
07/10/21 07:58 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Larry I will be retrofitting a hydroboost system for the extra room since the small booster is now unobtanium.
Re: 1.6 rockers and 440 valve covers [Re: mgoblue9798] #2941899
07/10/21 08:09 PM
07/10/21 08:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I thought rockauto had them but now I see its "return and rebuild" so I guess I still need booster. Dang I thought I had this one checked off. I have mounts, oil pan, valve covers and kickdown.
I wish Bouchillon would start selling them again. https://bouchillonperformance.com/inc/sdetail/428/432
I sent them an email asking if they might start and I'm ready to buy.
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2941912
07/10/21 09:17 PM
07/10/21 09:17 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I have read that some have been able to squeeze in a 440 with the big booster, but I suspect it was with worn out pancaked motor mounts. I don't remember if there is enough room to relocate the big booster closer to the lt fender or not.
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2941958
07/11/21 03:42 AM
07/11/21 03:42 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
To keep the oil from spraying at the air circulation provisions for PVC on one side and the filter on the other side.
Re: 1.6 rockers and 440 valve covers [Re: ek3] #2941988
07/11/21 10:35 AM
07/11/21 10:35 AM
Wi.
old_racer Online content
old_racer  Online Content
Wi.
we just drilled holes in the baffles where they hit. been working so far.
Re: 1.6 rockers and 440 valve covers [Re: old_racer] #2942006
07/11/21 12:07 PM
07/11/21 12:07 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Got it Nacho thanks. And I'll dent or drill I guess for the rockers. Marsh performance (Todd) is supposed to be calling me this afternoon up
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2942043
07/11/21 02:19 PM
07/11/21 02:19 PM
moparx Offline
moparx  Offline
the baffles keep a majority of the oil flood and mist from the breather[s] and pvc valve. without them, you stand the chance of leaky breathers and ingesting oil through the pvc.
there is no appreciable rigidity to amount involved.
beer
Re: 1.6 rockers and 440 valve covers [Re: moparx] #2942055
07/11/21 02:58 PM
07/11/21 02:58 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
beer
Okay I know I am showing some ignorance here and figured rigidity would have been accomplished differently but they are so close to the top I wasn't sure. Thank you all up
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2942062
07/11/21 03:10 PM
07/11/21 03:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Stock covers are pretty dang rigid, except of course the gasket rails when guys herk the bolts down like they're main caps.
Another interference spot I've experienced was at the shaft hold-downs at the ends.
That and roller rocker clearance is what led me to make the VC spacers, but I couldn't sell enough of 'em to afford making them.
I'd prefer denting the baffles to drilling them, if possible: dents don't create metal debris or slivers that can break off later.
Just cradle the VC & use a punch.
Re: 1.6 rockers and 440 valve covers [Re: larrymopar360] #2942094
07/11/21 04:51 PM
07/11/21 04:51 PM
E
ek3 Offline
ek3  Offline
E
you can also use the extra thick gaskets to gain a little more clearance ...
Re: 1.6 rockers and 440 valve covers [Re: ek3] #2942114
07/11/21 06:13 PM
07/11/21 06:13 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Is this on an A body or what, Heres a picture of my engine bay and there is plenty of room for the booster. 72 'Cuda.
Re: 1.6 rockers and 440 valve covers [Re: Cudajon] #2942609
07/13/21 12:19 PM
07/13/21 12:19 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
CudaJohn; my truck is a '79 and they didn't come with BB so I need to get earlier truck booster according to the experts here. It's a very tight fit. up
Btw, had a great conversation with Todd Marsh of Marsh Performance. Seems like a really good and knowledgeable guy! We talked a long time and and put down a good plan and I'm waiting on an invoice from him later in week or beginning of next week. My gut feeling is I'll be going with him to build my engine for truck.
