1.6 rockers and 440 valve covers
#2941792
07/10/21 01:03 PM
07/10/21 01:03 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Generally speaking do 1.6 ratio rockers usually fit under stock 440 valve covers or is it flat out "no never"? Thank you.
Facts are stubborn things.
Re: 1.6 rockers and 440 valve covers
[Re: larrymopar360]
#2941806
07/10/21 01:59 PM
07/10/21 01:59 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
Generally speaking do 1.6 ratio rockers usually fit under stock 440 valve covers or is it flat out "no never"? Thank you. i have the huges in mine. the baffles needed a small dent put in them where the adjustment nut contacts them .a very small dent l. . stock 440-6 valve covers -71 style
[Re: larrymopar360]
#2941857
07/10/21 05:07 PM
07/10/21 05:07 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Generally speaking do 1.6 ratio rockers usually fit under stock 440 valve covers or is it flat out "no never"? Thank you. It'll depend on the profile of the rocker, and what year stock valve covers your using, I got Crane 1.6 arms on my 440, using 70 440 stock valve covers, I had to lose the baffles in the cover to clear the arms/adjusters, some applications you can get by using cover spacers, or dimpling the baffles for clearance, or if you have the room, relocate/reweld the baffles closer to the top of the cover....
[Re: DAYCLONA]
#2941881
07/10/21 06:45 PM
07/10/21 06:45 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Okay I'll figure out soon which I'll be using and what year covers I have Are those baffles for rigidity? It's hard to imagine what they are accomplishing so close to the top.
[Re: mgoblue9798]
#2941899
07/10/21 08:09 PM
07/10/21 08:09 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Good info thank you! Trying to buy crate engine and many have 1.6's but I need/want stock valve covers because I like and to fit under booster on truck Larry I will be retrofitting a hydroboost system for the extra room since the small booster is now unobtanium. I thought rockauto had them but now I see its "return and rebuild" so I guess I still need booster. Dang I thought I had this one checked off. I have mounts, oil pan, valve covers and kickdown. I wish Bouchillon would start selling them again. https://bouchillonperformance.com/inc/sdetail/428/432 I sent them an email asking if they might start and I'm ready to buy.
[Re: larrymopar360]
#2941912
07/10/21 09:17 PM
07/10/21 09:17 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Good info thank you! Trying to buy crate engine and many have 1.6's but I need/want stock valve covers because I like and to fit under booster on truck Larry I will be retrofitting a hydroboost system for the extra room since the small booster is now unobtanium. I thought rockauto had them but now I see its "return and rebuild" so I guess I still need booster. Dang I thought I had this one checked off. I have mounts, oil pan, valve covers and kickdown. I wish Bouchillon would start selling them again. https://bouchillonperformance.com/inc/sdetail/428/432 I sent them an email asking if they might start and I'm ready to buy. I have read that some have been able to squeeze in a 440 with the big booster, but I suspect it was with worn out pancaked motor mounts. I don't remember if there is enough room to relocate the big booster closer to the lt fender or not.
[Re: larrymopar360]
#2941958
07/11/21 03:42 AM
07/11/21 03:42 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Okay I'll figure out soon which I'll be using and what year covers I have Are those baffles for rigidity? It's hard to imagine what they are accomplishing so close to the top. To keep the oil from spraying at the air circulation provisions for PVC on one side and the filter on the other side.
[Re: ek3]
#2941988
07/11/21 10:35 AM
07/11/21 10:35 AM
Posts: 1,401 Wi.
old_racer
Wi.
Generally speaking do 1.6 ratio rockers usually fit under stock 440 valve covers or is it flat out "no never"? Thank you. i have the huges in mine. the baffles needed a small dent put in them where the adjustment nut contacts them .a very small dent l. . stock 440-6 valve covers -71 style we just drilled holes in the baffles where they hit. been working so far.
[Re: old_racer]
#2942006
07/11/21 12:07 PM
07/11/21 12:07 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Generally speaking do 1.6 ratio rockers usually fit under stock 440 valve covers or is it flat out "no never"? Thank you. i have the huges in mine. the baffles needed a small dent put in them where the adjustment nut contacts them .a very small dent l. . stock 440-6 valve covers -71 style we just drilled holes in the baffles where they hit. been working so far. Got it Nacho thanks. And I'll dent or drill I guess for the rockers. Marsh performance (Todd) is supposed to be calling me this afternoon
[Re: moparx]
#2942055
07/11/21 02:58 PM
07/11/21 02:58 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
the baffles keep a majority of the oil flood and mist from the breather[s] and pvc valve. without them, you stand the chance of leaky breathers and ingesting oil through the pvc. there is no appreciable rigidity to amount involved. Okay I know I am showing some ignorance here and figured rigidity would have been accomplished differently but they are so close to the top I wasn't sure. Thank you all
[Re: ek3]
#2942114
07/11/21 06:13 PM
07/11/21 06:13 PM
Posts: 1,436 Oklahoma City OK
Cudajon
Oklahoma City OK
Is this on an A body or what, Heres a picture of my engine bay and there is plenty of room for the booster. 72 'Cuda.
[Re: Cudajon]
#2942609
07/13/21 12:19 PM
07/13/21 12:19 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
CudaJohn; my truck is a '79 and they didn't come with BB so I need to get earlier truck booster according to the experts here. It's a very tight fit. Btw, had a great conversation with Todd Marsh of Marsh Performance. Seems like a really good and knowledgeable guy! We talked a long time and and put down a good plan and I'm waiting on an invoice from him later in week or beginning of next week. My gut feeling is I'll be going with him to build my engine for truck.
