Originally Posted by larrymopar360
Good info thank you! Trying to buy crate engine and many have 1.6's but I need/want stock valve covers because I like and to fit under booster on truck up
Larry I will be retrofitting a hydroboost system for the extra room since the small booster is now unobtanium.
I thought rockauto had them but now I see its "return and rebuild" so I guess I still need booster. Dang I thought I had this one checked off. I have mounts, oil pan, valve covers and kickdown.
I wish Bouchillon would start selling them again. https://bouchillonperformance.com/inc/sdetail/428/432
I sent them an email asking if they might start and I'm ready to buy.
I have read that some have been able to squeeze in a 440 with the big booster, but I suspect it was with worn out pancaked motor mounts. I don't remember if there is enough room to relocate the big booster closer to the lt fender or not.
