Re: Looking for valve spring recommendations
[Re: bracketcharger]
#2906369
04/04/21 04:59 PM
04/04/21 04:59 PM
Posts: 4,206 New York
polyspheric
New York
The higher ratio increases the spring load on the valve by the change proportion. A spring using 1.6:1 will increase the open load by 6.7% (1.6 รท 1.5), a 500 lb. spring becomes 533. The closed load won't change. The 1.6:1 rocker will also increase the load on the tappet & lobe in the same proportion. The 500 lb. spring was 750 lbs. with the 1.5:1 rocker, becomes 800 lbs with the 1.6:1.
Boffin Emeritus
[Re: B1MAXX]
#2906391
04/04/21 06:01 PM
04/04/21 06:01 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
Never trust the specs. furnish with the springs with no way to verify the actual pressures Take them to a shop with a good valve spring tester and have them set your springs up while verifying the pressures, I like to see 140 to 160 lbs. on the seats and from 325 to 375 lbs. at max lift with at least .060 from coil bind on all 16 springs You need to use a set, pair of, checking springs to get the actual lift at the valves first before setting the springs up so you know the true max lift with your rocker arms also On a hydralic flat tappet? Absolutely on Mopar V8 with stock .904 lifters
[Re: Cab_Burge]
#2906543
04/04/21 08:42 PM
04/04/21 08:42 PM
Posts: 1,991 Apollo, PA.
B1MAXX
Apollo, PA.
Never trust the specs. furnish with the springs with no way to verify the actual pressures Take them to a shop with a good valve spring tester and have them set your springs up while verifying the pressures, I like to see 140 to 160 lbs. on the seats and from 325 to 375 lbs. at max lift with at least .060 from coil bind on all 16 springs You need to use a set, pair of, checking springs to get the actual lift at the valves first before setting the springs up so you know the true max lift with your rocker arms also On a hydralic flat tappet? Absolutely on Mopar V8 with stock .904 lifters mopar recommened the P3690933 spring with that cam it was 115 on the seat, and 310 over the nose. But hey ok.
