Looking for valve spring recommendations #2906037
04/04/21 09:57 AM
04/04/21 09:57 AM
Vermont
bracketcharger Offline OP
Vermont
I'm hoping to get some recommendations for valve springs. Engine is a 440 with Mopar performance 292 .509 cam, 3/8 pushrods, Hughes 1.6 rocker arms. Heads are #452 cast iron, ported and flow 276 at .540 lift. Valve guides have been cut for PC valve seats so plenty of clearance for this lift. I presently have a set of fresh Comp 911-16 springs. With the Comp springs I have plenty of room before coil bind comes into play. Wondering if the higher ratio rocker arms will require a stiffer spring. Thanks in advance for any assistance.
Happy Easter
Re: Looking for valve spring recommendations [Re: bracketcharger] #2906072
04/04/21 10:23 AM
04/04/21 10:23 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Sounds ok to me. I would think that's plenty of spring for that combo. 122 on the seat @1.900 and 320 over the nose.
Re: Looking for valve spring recommendations [Re: B1MAXX] #2906188
04/04/21 12:23 PM
04/04/21 12:23 PM
Vermont
Vermont
Thanks B1MAXX I guess I was just over thinking it. Cheers !
Re: Looking for valve spring recommendations [Re: bracketcharger] #2906227
04/04/21 12:59 PM
04/04/21 12:59 PM
Never trust the specs. furnish with the springs with no way to verify the actual pressures twocents
Take them to a shop with a good valve spring tester and have them set your springs up while verifying the pressures, I like to see 140 to 160 lbs. on the seats and from 325 to 375 lbs. at max lift with at least .060 from coil bind on all 16 springs scope
You need to use a set, pair of, checking springs to get the actual lift at the valves first before setting the springs up so you know the true max lift with your rocker arms also scope up
Re: Looking for valve spring recommendations [Re: Cab_Burge] #2906263
04/04/21 01:32 PM
04/04/21 01:32 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
On a hydralic flat tappet?
Re: Looking for valve spring recommendations [Re: bracketcharger] #2906369
04/04/21 04:59 PM
04/04/21 04:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The higher ratio increases the spring load on the valve by the change proportion. A spring using 1.6:1 will increase the open load by 6.7% (1.6 รท 1.5), a 500 lb. spring becomes 533. The closed load won't change.
The 1.6:1 rocker will also increase the load on the tappet & lobe in the same proportion. The 500 lb. spring was 750 lbs. with the 1.5:1 rocker, becomes 800 lbs with the 1.6:1.
Boffin Emeritus
Re: Looking for valve spring recommendations [Re: B1MAXX] #2906391
04/04/21 06:01 PM
04/04/21 06:01 PM
Absolutely on Mopar V8 with stock .904 lifters up
Re: Looking for valve spring recommendations [Re: Cab_Burge] #2906543
04/04/21 08:42 PM
04/04/21 08:42 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
mopar recommened the P3690933 spring with that cam it was 115 on the seat, and 310 over the nose.
But hey ok. beer
