USB Turntables for converting vinyl albums to digital #2821322
09/15/20 10:53 PM
09/15/20 10:53 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
USB Turntables for converting vinyl albums (records) to digital, anyone have one? How's the basic quality? I know that's relative but I have a couple of hundred vinyl albums from the '70's, '80's and even some from later that I would like to convert just for the heck of it. Anyone have some experience with them? TIA.
Mike
Re: USB Turntables for converting vinyl albums to digital [Re: A12] #2821327
09/15/20 11:16 PM
09/15/20 11:16 PM
5thAve Offline
5thAve  Offline
I forget what the software was called now because it's been years since I used it but the last records I did I used an adapter to connect a normal turntable which is better quality then the USB ones to the computer and the program could take the records as-is or clean up the sound.
At the end I found that I liked having digital copies of my favorite records but prefer listening to either the real thing or a clean digital copy.
Re: USB Turntables for converting vinyl albums to digital [Re: 5thAve] #2821338
09/16/20 12:04 AM
09/16/20 12:04 AM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
I have one. The brand is Crosley. Works fine. Just a basic turntable with a USB port and connections for speakers if you just want to listen to it. Plug your computer into the turn table and the computer gets the music as a digital file. Can't remember the file specifics, haven't used it in a while. Bought it, saved a bunch of albums digitally and now it just sits. Wasn't a lot of money when I bought it. No regrets.
Re: USB Turntables for converting vinyl albums to digital [Re: A12] #2821401
09/16/20 08:55 AM
09/16/20 08:55 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Mine's an ION, pretty easy to use but not overly happy with the software - it wants to organize all cuts off the album alphabetically which sucks on an anthology type album. Other than that I like it, but it does mostly sit now.
Re: USB Turntables for converting vinyl albums to digital [Re: A12] #2821428
09/16/20 09:58 AM
09/16/20 09:58 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
There are many USB turntables available some cheap ones, some better ones...
The most reliable are from Audio-Technica...
Regarding sonic quality, being digitized to MP3 the higher the sampling rate the better the audio quality but the higher rate use more memory store space.
For reasonable quality use a rate @ least 160 or higher..
Just my $0.02... wink
Re: USB Turntables for converting vinyl albums to digital [Re: Sinitro] #2821494
09/16/20 12:02 PM
09/16/20 12:02 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've got one. It recommends Audacity, which works well, BUT it found way too many breaks when trying to separate songs. I digitized a couple of albums, but it was very time consuming. I'll get back to it one of these days.
Re: USB Turntables for converting vinyl albums to digital [Re: Sinitro] #2821981
09/17/20 05:06 PM
09/17/20 05:06 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Agree on all of this. You will hear compression at 128 or lower. If you want an all-encompassing solution I'd buy one of the Audio-Technica USB based turntables. If you have a turntable you're happy with the quality of already, you could buy an analog to digital converter and software for ripping vinyl.
Re: USB Turntables for converting vinyl albums to digital [Re: A12] #2822692
09/19/20 06:49 PM
09/19/20 06:49 PM
Anderson, SC
resqguy Offline
resqguy  Offline
Anderson, SC
I use Audacity software and a regular turntable with a modern cartridge. I digitize to a lossless format and a minimum sample rate of 44k. It is tedious work starting with the cleaning of the LP, manually filtering scratches, and manually separating tracks. In the end it is mostly worth it. Many of the CD versions of the material are poorly produced/compressed. The remastered versions are mostly better, it is still hit and miss where the original vinyl is sometimes better. Best to take it case by case.
