Re: USB Turntables for converting vinyl albums to digital
[Re: A12]
#2821428
09/16/20 09:58 AM
09/16/20 09:58 AM
Posts: 5,435 So Cal
Sinitro
So Cal
There are many USB turntables available some cheap ones, some better ones... The most reliable are from Audio-Technica... Regarding sonic quality, being digitized to MP3 the higher the sampling rate the better the audio quality but the higher rate use more memory store space. For reasonable quality use a rate @ least 160 or higher.. Just my $0.02...
[Re: Sinitro]
#2821981
09/17/20 05:06 PM
09/17/20 05:06 PM
Posts: 8,156 Plymouth, MI
Blusmbl
Plymouth, MI
There are many USB turntables available some cheap ones, some better ones... The most reliable are from Audio-Technica... Regarding sonic quality, being digitized to MP3 the higher the sampling rate the better the audio quality but the higher rate use more memory store space. For reasonable quality use a rate @ least 160 or higher.. Just my $0.02... Agree on all of this. You will hear compression at 128 or lower. If you want an all-encompassing solution I'd buy one of the Audio-Technica USB based turntables. If you have a turntable you're happy with the quality of already, you could buy an analog to digital converter and software for ripping vinyl.
