Powder coating air cleaners #2815803
09/01/20 09:53 AM
09/01/20 09:53 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve heard of good looking results with powder coating on dual snorkel air cleaners but I was wondering if the heat of the oven destroyed the diaphragm on the snorkel. Anyone?
Re: Powder coating air cleaners [Re: fastmark] #2816075
09/02/20 01:51 AM
09/02/20 01:51 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
375 to 425 deg F. Think that rubber inside will tolerate that temp?
Re: Powder coating air cleaners [Re: PhillyRag] #2816109
09/02/20 07:39 AM
09/02/20 07:39 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
That’s why I’m asking. I don’t think it’s a good idea but I’m sure someone has tried it.
Re: Powder coating air cleaners [Re: fastmark] #2816140
09/02/20 09:47 AM
09/02/20 09:47 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I doubt the air cleaner diaphragm sees that kind of temp in normal operation.
But I don't know the design or operating limits on that, either.
If it's on a running car, build some temp underhood on a hot day and check it with a heat gun.
Re: Powder coating air cleaners [Re: fastmark] #2816527
09/03/20 03:47 AM
09/03/20 03:47 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
May not totally wreck the rubber, but would guess to say would have a neg. effect (shrink it, or such). Best option is to paint those parts with wrinkle paint. Lowest temp I've used for powder coating is 375F, but believe 30 minutes. If you have a spare one, can bake it & see. If not, not worth the risk. I'd doubt it is ever exposed to those temps while in use. One of the pit-falls of P-C on cleaners with diaphragms.
Re: Powder coating air cleaners [Re: PhillyRag] #2816531
09/03/20 06:01 AM
09/03/20 06:01 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I did a 71 dual snorker and my powder coating guy said that the heat would ruin the pods. So I pained the pods to match.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Powder coating air cleaners [Re: moparmarks] #2816536
09/03/20 06:18 AM
09/03/20 06:18 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks. Are the pods easy to r and r?
Re: Powder coating air cleaners [Re: fastmark] #2816649
09/03/20 12:52 PM
09/03/20 12:52 PM
moparx Offline
moparx  Offline
i can't remember exactly, but i think those are attached by just a couple of tabs that get bent over, retaining the can to the housing.
i don't remember if the tabs are on the cans or the housings.
would it be possible to use a rattle can of wrinkle paint on the cans, then use a heat gun on a somewhat low heat to help the wrinkle effect ?
passing the gun back and forth somewhat quickly "should" help the wrinkle effect without heating the can up to the point of destroying the rubber diaphragm.
just a thought. please correct this if i'm wrong in my thinking.
beer
Re: Powder coating air cleaners [Re: moparx] #2816677
09/03/20 01:43 PM
09/03/20 01:43 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I powder coated my 1970 twin snorkel. The vacuum pods still work. I don't have them plumbed to the engine anyway, so it wasn't an issue. But, I was curious to see.
Re: Powder coating air cleaners [Re: 469runner] #2816756
09/03/20 05:30 PM
09/03/20 05:30 PM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
Leanna (cudachick1968 @ FABO) would know! Try here:http://phoenixspecialtycoatings.com/index.html
Re: Powder coating air cleaners [Re: 469runner] #2817538
09/05/20 05:55 PM
09/05/20 05:55 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Same here. I did mine and they still worked.
For what we used these cars for nowadays, you don't need them.
Re: Powder coating air cleaners [Re: fastmark] #2817652
09/05/20 11:16 PM
09/05/20 11:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There's a new line of Powder coatings that are UV cured for items that can't handle the heat curing process that standard powders are cured at, the UV cured powders are also for non conductive components that you may require coated as well...
Mike
Re: Powder coating air cleaners [Re: fastmark] #2819565
09/11/20 02:44 AM
09/11/20 02:44 AM
I won't powder coat anything on the intake side of a motor again after trying it once tsk ONLY once.
The powder coating holds the heat in not allowing the part to cool down like normal down at least it did that on the aluminum intake and M/T valve covers I had done whiney
Re: Powder coating air cleaners [Re: Cab_Burge] #2819673
09/11/20 01:01 PM
09/11/20 01:01 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
dont ruin the pods, they are hard to find and $$ when they surface in NOS. I am not sure if they are reproduced yet. be careful. i painted mine with the wrinkle finish and powder coated the rest of the outer dual snorkel. I believe the inside of the housing where the filter sits is black.
Super Commando
