Re: Powder coating air cleaners
[Re: fastmark]
#2816075
09/02/20 01:51 AM
09/02/20 01:51 AM
Posts: 1,757 Phila
PhillyRag
Phila
I’ve heard of good looking results with powder coating on dual snorkel air cleaners but I was wondering if the heat of the oven destroyed the diaphragm on the snorkel. Anyone? 375 to 425 deg F. Think that rubber inside will tolerate that temp?
[Re: PhillyRag]
#2816109
09/02/20 07:39 AM
09/02/20 07:39 AM
Posts: 6,416 Abilene, Texas
fastmark
Abilene, Texas
I’ve heard of good looking results with powder coating on dual snorkel air cleaners but I was wondering if the heat of the oven destroyed the diaphragm on the snorkel. Anyone? 375 to 425 deg F. Think that rubber inside will tolerate that temp? That’s why I’m asking. I don’t think it’s a good idea but I’m sure someone has tried it.
[Re: fastmark]
#2816527
09/03/20 03:47 AM
09/03/20 03:47 AM
Posts: 1,757 Phila
PhillyRag
Phila
I’ve heard of good looking results with powder coating on dual snorkel air cleaners but I was wondering if the heat of the oven destroyed the diaphragm on the snorkel. Anyone? 375 to 425 deg F. Think that rubber inside will tolerate that temp? That’s why I’m asking. I don’t think it’s a good idea but I’m sure someone has tried it. May not totally wreck the rubber, but would guess to say would have a neg. effect (shrink it, or such). Best option is to paint those parts with wrinkle paint. Lowest temp I've used for powder coating is 375F, but believe 30 minutes. If you have a spare one, can bake it & see. If not, not worth the risk. I'd doubt it is ever exposed to those temps while in use. One of the pit-falls of P-C on cleaners with diaphragms.
[Re: fastmark]
#2816649
09/03/20 12:52 PM
09/03/20 12:52 PM
Posts: 19,464 north of coder
moparx
Thanks. Are the pods easy to r and r? i can't remember exactly, but i think those are attached by just a couple of tabs that get bent over, retaining the can to the housing. i don't remember if the tabs are on the cans or the housings. would it be possible to use a rattle can of wrinkle paint on the cans, then use a heat gun on a somewhat low heat to help the wrinkle effect ? passing the gun back and forth somewhat quickly "should" help the wrinkle effect without heating the can up to the point of destroying the rubber diaphragm. just a thought. please correct this if i'm wrong in my thinking.
[Re: 469runner]
#2817538
09/05/20 05:55 PM
09/05/20 05:55 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I powder coated my 1970 twin snorkel. The vacuum pods still work. I don't have them plumbed to the engine anyway, so it wasn't an issue. But, I was curious to see. Same here. I did mine and they still worked. For what we used these cars for nowadays, you don't need them.
[Re: fastmark]
#2819565
09/11/20 02:44 AM
09/11/20 02:44 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
I won't powder coat anything on the intake side of a motor again after trying it once ONLY once. The powder coating holds the heat in not allowing the part to cool down like normal at least it did that on the aluminum intake and M/T valve covers I had done
[Re: Cab_Burge]
#2819673
09/11/20 01:01 PM
09/11/20 01:01 PM
Posts: 1,083 Long Island, NY
70plymA34
Long Island, NY
dont ruin the pods, they are hard to find and $$ when they surface in NOS. I am not sure if they are reproduced yet. be careful. i painted mine with the wrinkle finish and powder coated the rest of the outer dual snorkel. I believe the inside of the housing where the filter sits is black.
Super Commando
