Sticky REAL street radial
#2801924
07/27/20 09:16 PM
07/27/20 09:16 PM
Posts: 1,368 Houston,Tx.
Lee446
Houston,Tx.
Gentlemen, I have a problem. Due to my imminent relocation to a more rural area, including having to drive a couple of miles on a county gravel road to get to the blacktop, my Hemi powered 'Cuda is going to become a road car and as such, Drag radials will not be an option. I am looking for the stickiest true road radial for a 17x9" wheel and I want a 27-28" tall tire and that cuts the field by a bunch, 26" just does not look right. About the closest I can find is the Nitto 555g that is rated at 200 treadwear in the 275-50-17. This is my wifes toy but with a touch over 700 hp, it is flat dangerous on the gas and at hiway speed if it downshifts to second, it gets real loose real quick. If anyone has a recommendation, I am all ears.
Re: Sticky REAL street radial
[Re: Lee446]
#2801939
07/27/20 10:18 PM
07/27/20 10:18 PM
Posts: 2,674 Pattison Texas
csk
Pattison Texas
I had Nitto 555R on my Charger, not much better than a regular 50k mile street tire. I now have MT street R radials, they hook great but the Houston heat makes them prone to punctures from rocks or anything that is even slightly sharp .
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392
[Re: ksj]
#2801942
07/27/20 10:28 PM
07/27/20 10:28 PM
csk
Pattison Texas
Sorry thats what it was, forgot the R Same junk
[Re: Lee446]
#2801958
07/27/20 11:16 PM
07/27/20 11:16 PM
csk
Pattison Texas
All of the Nitto competition tires in 17" are under 26" tall. I used to have good luck with M/T et streets but they quit making a 28" tall 17 " tire and I could not run them anyway, gravel roads are hard on all tires, but they are really hard on the soft drag radials. M & H has some 28in x 17 Drag Radials https://www.mandhtires.com/M-H-Drag-Tires/M-H-Drag-Radials
[Re: mopar dave]
#2802015
07/28/20 07:20 AM
07/28/20 07:20 AM
Lee446
Houston,Tx.
Drag radials are out of the question. This will be more of a road/hiway car now, and I need a speed rated tire that is safe if it rains, Think Power Tour type driving. I realize that I am not going to find anything that will really hook up, but I am trying to find the best compromise street radial I can find. The biggest problem for me is that most of the modern size 17's are 35 maybe 40 aspect tires and are 25-26" tall. The M/T sr is not available in a 17" tire more than 8" wide, if they had a 275/50/17, I would buy it.
[Re: Lee446]
#2802059
07/28/20 08:57 AM
07/28/20 08:57 AM
Posts: 2,191 IL
furious70
IL
I have a set of these that are a huge improvement over the 'regular' tires I used to run. I have no idea how they compare to other 'ultra' tires but they are affordable to try. Probably too tall for you though: https://www.atturo.com/tire/az800/6771
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Lee446]
#2802164
07/28/20 02:04 PM
07/28/20 02:04 PM
Posts: 1,623 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Hmm...great experience with the Nitto 555Rs here. Mind you that's behind a decent 360 motor, 4K converter stall and 4.10 gear, so that does put a bit of beating on the tires. If I aim for it yes, of course I'll leave a set of tire marks on the pavement, but with that stall speed I found a good launch to be more about easing into the engine RPMs.
I suppose what works for me is that I'm running them at 20 psi, the tires being: 275-60R15s, so plenty of sidewall.
[Re: Lee446]
#2802209
07/28/20 03:47 PM
07/28/20 03:47 PM
csk
Pattison Texas
I looked all over & it would seem the Nitto is about it, Goodyear has some 17's but they look like a light truck tire.
[Re: csk]
#2802217
07/28/20 04:16 PM
07/28/20 04:16 PM
Posts: 9,023 Rogue River, OR
Jeremiah
Rogue River, OR
I have been experimenting with a set of Vitour Galaxy radials from eBay on my '68 GTS 383 4-speed car. They are cheap for testing and so far no issues. The problem with any sticky tire is that gravel won't know if it's a drag tire or not. No sticky, no traction. Big sticky, big rock chips. This is coming from a guy that has a loooooooooong gravel road to his house. If it was me I'd run a set of M&H DOT radials. They are best of both worlds IMO.
[Re: Jeremiah]
#2802558
07/29/20 02:06 PM
07/29/20 02:06 PM
Posts: 1,386 NW Chicago suburban area
Mopar Mitch
The problem with 17s.. is getting soft tread wear (such as 200) in a diameter that is a little tall (ie: 27-28"... doesn't exist). Simply, there aren't many sizes available in soft compound, such as 200.
Step up to 18s and there are many more sizes in soft compound, such as 200 TW.
Take a look over at the Tire Rack web site.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2803393
07/31/20 05:41 PM
07/31/20 05:41 PM
Posts: 4,389 The Pale Blue Dot
Skeptic
The Pale Blue Dot
The MT Street S/S 305/45-17 looks right up your alley, though hooking up 700 HP on the street isn't gonna be easy. Edit-with a 9" wheel , it's a bit narrow, you should go for a 10" to get it done./edit
[Re: Skeptic]
#2803591
08/01/20 07:59 AM
08/01/20 07:59 AM
Posts: 9,678 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Check the Mustang6G site in the GT500 section or other related sections to see how the Michelin PS4 compares. They come on on performance pack GT Mustangs. I have a. 19 GT with them and they are about as good as a 30,000 mile tire gets IMHO. But you have a lot more torque so asking the GT500 crowd might offer more info.
8.77 153 mph best, 3055 lbs 528 indy 440-1 alky
[Re: Lee446]
#2803984
08/01/20 09:10 PM
08/01/20 09:10 PM
Posts: 11,500 W. Kentucky
justinp61
W. Kentucky
Gentlemen, I have a problem. Due to my imminent relocation to a more rural area, including having to drive a couple of miles on a county gravel road to get to the blacktop, my Hemi powered 'Cuda is going to become a road car and as such, Drag radials will not be an option. I am looking for the stickiest true road radial for a 17x9" wheel and I want a 27-28" tall tire and that cuts the field by a bunch, 26" just does not look right. About the closest I can find is the Nitto 555g that is rated at 200 treadwear in the 275-50-17. This is my wifes toy but with a touch over 700 hp, it is flat dangerous on the gas and at hiway speed if it downshifts to second, it gets real loose real quick. If anyone has a recommendation, I am all ears. Sticky tires + gravel roads = not good for the paint.
