Sticky REAL street radial #2801924
07/27/20 10:16 PM
07/27/20 10:16 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
Gentlemen, I have a problem. Due to my imminent relocation to a more rural area, including having to drive a couple of miles on a county gravel road to get to the blacktop, my Hemi powered 'Cuda is going to become a road car and as such, Drag radials will not be an option. I am looking for the stickiest true road radial for a 17x9" wheel and I want a 27-28" tall tire and that cuts the field by a bunch, 26" just does not look right. About the closest I can find is the Nitto 555g that is rated at 200 treadwear in the 275-50-17. This is my wifes toy but with a touch over 700 hp, it is flat dangerous on the gas and at hiway speed if it downshifts to second, it gets real loose real quick. If anyone has a recommendation, I am all ears.
Re: Sticky REAL street radial [Re: Lee446] #2801939
07/27/20 11:18 PM
07/27/20 11:18 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I had Nitto 555R on my Charger, not much better than a regular 50k mile street tire. I now have MT street R radials, they hook great but the Houston heat makes them prone to punctures from rocks or anything that is even slightly sharp .
Re: Sticky REAL street radial [Re: CSK] #2801940
07/27/20 11:19 PM
07/27/20 11:19 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
What about Nitto 555R.
Re: Sticky REAL street radial [Re: ksj] #2801942
07/27/20 11:28 PM
07/27/20 11:28 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Sorry thats what it was, forgot the R Same junk
Re: Sticky REAL street radial [Re: CSK] #2801944
07/27/20 11:39 PM
07/27/20 11:39 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
All of the Nitto competition tires in 17" are under 26" tall. I used to have good luck with M/T et streets but they quit making a 28" tall 17 " tire and I could not run them anyway, gravel roads are hard on all tires, but they are really hard on the soft drag radials.
Re: Sticky REAL street radial [Re: Lee446] #2801955
07/28/20 12:13 AM
07/28/20 12:13 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Problem with anything sticky on gravel is they pitch the small stones into the paint.
I have to creep one of my cars down the gravel, and those are a Cooper Extreme Summer handling tires.
Re: Sticky REAL street radial [Re: Lee446] #2801958
07/28/20 12:16 AM
07/28/20 12:16 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
M & H has some 28in x 17 Drag Radials
https://www.mandhtires.com/M-H-Drag-Tires/M-H-Drag-Radials
Re: Sticky REAL street radial [Re: Lee446] #2802003
07/28/20 07:46 AM
07/28/20 07:46 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I would take a look at the M/T S/R radial. I believe there about as soft as you will find in a street tire. I had a racer over on B bodies tell me they are the same compound as the M/T street R radial which i use and they are super sticky at the track.
Re: Sticky REAL street radial [Re: mopar dave] #2802015
07/28/20 08:20 AM
07/28/20 08:20 AM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
Drag radials are out of the question. This will be more of a road/hiway car now, and I need a speed rated tire that is safe if it rains, Think Power Tour type driving. I realize that I am not going to find anything that will really hook up, but I am trying to find the best compromise street radial I can find. The biggest problem for me is that most of the modern size 17's are 35 maybe 40 aspect tires and are 25-26" tall. The M/T sr is not available in a 17" tire more than 8" wide, if they had a 275/50/17, I would buy it.
Re: Sticky REAL street radial [Re: Lee446] #2802059
07/28/20 09:57 AM
07/28/20 09:57 AM
IL
furious70 Offline
furious70  Offline
IL
I have a set of these that are a huge improvement over the 'regular' tires I used to run. I have no idea how they compare to other 'ultra' tires but they are affordable to try. Probably too tall for you though:
https://www.atturo.com/tire/az800/6771
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Sticky REAL street radial [Re: ksj] #2802122
07/28/20 12:44 PM
07/28/20 12:44 PM
central il.
second 70 Offline
second 70  Offline
central il.
They ride good but are useless on my hemi cuda. I got better traction from old polyglass tires.
Re: Sticky REAL street radial [Re: second 70] #2802147
07/28/20 02:27 PM
07/28/20 02:27 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
We call them Shittos.
'63 Dodge 330
11.19 @ 121 mph
Re: Sticky REAL street radial [Re: Lee446] #2802164
07/28/20 03:04 PM
07/28/20 03:04 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Hmm...great experience with the Nitto 555Rs here. Mind you that's behind a decent 360 motor, 4K converter stall and 4.10 gear, so that does put a bit of beating on the tires. If I aim for it yes, of course I'll leave a set of tire marks on the pavement, but with that stall speed I found a good launch to be more about easing into the engine RPMs.
I suppose what works for me is that I'm running them at 20 psi, the tires being: 275-60R15s, so plenty of sidewall.
Re: Sticky REAL street radial [Re: Lee446] #2802209
07/28/20 04:47 PM
07/28/20 04:47 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I looked all over & it would seem the Nitto is about it, Goodyear has some 17's but they look like a light truck tire.
Re: Sticky REAL street radial [Re: CSK] #2802217
07/28/20 05:16 PM
07/28/20 05:16 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have been experimenting with a set of Vitour Galaxy radials from eBay on my '68 GTS 383 4-speed car. They are cheap for testing and so far no issues. The problem with any sticky tire is that gravel won't know if it's a drag tire or not. No sticky, no traction. Big sticky, big rock chips. This is coming from a guy that has a loooooooooong gravel road to his house. If it was me I'd run a set of M&H DOT radials. They are best of both worlds IMO.
Re: Sticky REAL street radial [Re: Jeremiah] #2802558
07/29/20 03:06 PM
07/29/20 03:06 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The problem with 17s.. is getting soft tread wear (such as 200) in a diameter that is a little tall (ie: 27-28"... doesn't exist). Simply, there aren't many sizes available in soft compound, such as 200.
Step up to 18s and there are many more sizes in soft compound, such as 200 TW.
Take a look over at the Tire Rack web site.
Re: Sticky REAL street radial [Re: Mopar Mitch] #2803393
07/31/20 06:41 PM
07/31/20 06:41 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The MT Street S/S 305/45-17 looks right up your alley, though hooking up 700 HP on the street isn't gonna be easy. Edit-with a 9" wheel , it's a bit narrow, you should go for a 10" to get it done./edit
Re: Sticky REAL street radial [Re: Skeptic] #2803591
08/01/20 08:59 AM
08/01/20 08:59 AM
gregsdart Online content
gregsdart  Online Content
Check the Mustang6G site in the GT500 section or other related sections to see how the Michelin PS4 compares. They come on on performance pack GT Mustangs. I have a. 19 GT with them and they are about as good as a 30,000 mile tire gets IMHO. But you have a lot more torque so asking the GT500 crowd might offer more info.
Re: Sticky REAL street radial [Re: gregsdart] #2803849
08/01/20 06:27 PM
08/01/20 06:27 PM
Central NC
gch Offline
gch  Offline
Central NC
If you step down to the 255/50/17 the Nitto Invo is out there as well as the Federal ss595 if you can still find it.Both are 260 treadwear and the federal is a bunch cheaper.
Re: Sticky REAL street radial [Re: Lee446] #2803984
08/01/20 10:10 PM
08/01/20 10:10 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Sticky tires + gravel roads = not good for the paint.
