Water pump housing - iron vs aluminum #2760544
04/05/20 09:34 PM
04/05/20 09:34 PM
Annapolis, MD, USA
V
Vert Offline OP
Vert  Offline OP
V
Annapolis, MD, USA
Thought I'd check the weight before installing.
Re: Water pump housing - iron vs aluminum [Re: Vert] #2760575
04/05/20 10:31 PM
04/05/20 10:31 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Now weigh the water pumps!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Water pump housing - iron vs aluminum [Re: hemi-itis] #2760583
04/05/20 10:43 PM
04/05/20 10:43 PM
8.5 lbs. weight savings off the front of the car in front of the spindles is good up twocents
Re: Water pump housing - iron vs aluminum [Re: hemi-itis] #2760588
04/05/20 10:55 PM
04/05/20 10:55 PM
Kirkland, Washington
Pacnorthcuda Offline
Exactly, the water pump is negligible, about 1 pound IIRC. I just gutted my 58 pound Mopar resto battery and installed an Odyssey, 29 pounds now. That’s some savings, and even further in front!
But yeah, I have AL heads, intake, WP, WPH, headers. Probably weighs what a stock small block weighed from the factory.
Re: Water pump housing - iron vs aluminum [Re: Pacnorthcuda] #2760666
04/06/20 10:16 AM
04/06/20 10:16 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I just did the same thing on my GTX. Nasty job.
Re: Water pump housing - iron vs aluminum [Re: OUTLAWSSAA] #2760679
04/06/20 10:47 AM
04/06/20 10:47 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Stuff like this gets me off! Really cool!
'63 Dodge 330
11.19 @ 121 mph
Re: Water pump housing - iron vs aluminum [Re: GY3] #2760695
04/06/20 11:16 AM
04/06/20 11:16 AM
On mine I cut a piece of 1/4 inch plywood for the bottom and epoxied 4 screws to act as locating pins only, no nuts. Then Velcro the batt to the wood, no movement, no foam. Now when I remove the batt hold down the cover will raise off the batt.
Re: Water pump housing - iron vs aluminum [Re: Pacnorthcuda] #2760703
04/06/20 11:41 AM
04/06/20 11:41 AM
GA
roadrunninMark Offline
GA
Those Oddessey batteries have about 380 CCA, is that enough power to turn over big engines/ high C.R.s?
Just found these on Summit... https://www.summitracing.com/parts/brl-b2317rp?rrec=true 17lbs, 475CCA (641 CA @ 32 deg), $200. A review says it will start a 13.1 CR 432 cube engine just fine.
Re: Water pump housing - iron vs aluminum [Re: roadrunninMark] #2760707
04/06/20 11:58 AM
04/06/20 11:58 AM
It’s working fine on my 10.2 : 1 440. But yeah, I’m a bit concerned about that too, especially as it ages. Other people report success though.
