Re: Water pump housing - iron vs aluminum
[Re: hemi-itis]
#2760588
04/05/20 10:55 PM
04/05/20 10:55 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Now weigh the water pumps! Exactly, the water pump is negligible, about 1 pound IIRC. I just gutted my 58 pound Mopar resto battery and installed an Odyssey, 29 pounds now. That’s some savings, and even further in front! But yeah, I have AL heads, intake, WP, WPH, headers. Probably weighs what a stock small block weighed from the factory.
[Re: OUTLAWSSAA]
#2760679
04/06/20 10:47 AM
04/06/20 10:47 AM
Posts: 4,676 Wichita
GY3
Wichita
I just did the same thing on my GTX. Nasty job. Stuff like this gets me off! Really cool!
[Re: Pacnorthcuda]
#2760703
04/06/20 11:41 AM
04/06/20 11:41 AM
Posts: 2,937 GA
roadrunninMark
GA
Those Oddessey batteries have about 380 CCA, is that enough power to turn over big engines/ high C.R.s? Just found these on Summit... https://www.summitracing.com/parts/brl-b2317rp?rrec=true 17lbs, 475CCA (641 CA @ 32 deg), $200. A review says it will start a 13.1 CR 432 cube engine just fine.
[Re: roadrunninMark]
#2760707
04/06/20 11:58 AM
04/06/20 11:58 AM
Pacnorthcuda
Those Oddessey batteries have about 380 CCA, is that enough power to turn over big engines/ high C.R.s? It’s working fine on my 10.2 : 1 440. But yeah, I’m a bit concerned about that too, especially as it ages. Other people report success though.
