Page 1 of 3 1 2 3
Race timing #2741353
02/09/20 08:05 PM
02/09/20 08:05 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Msd dist/ 511/ carb - run the fast springs for timing all in early or lock out the dist. - race only car.
Re: Race timing [Re: RustyM] #2741391
02/09/20 09:28 PM
02/09/20 09:28 PM
California, U.S.A.
Torquemonster440 Offline
California, U.S.A.
Race only, I'd say lock it out and forget it. If all you're concerned with is wot, locked out seems like the ticket to me.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Race timing [Re: RustyM] #2741401
02/09/20 09:51 PM
02/09/20 09:51 PM
Washington
madscientist Offline
Washington
If you lock it out and your box retards with RPM you'll be losing power from retarded timing with RPM.
Re: Race timing [Re: RustyM] #2741410
02/09/20 10:13 PM
02/09/20 10:13 PM
I use the weakest springs and the black stop in all my motors, race or street up
Re: Race timing [Re: Cab_Burge] #2741432
02/09/20 11:03 PM
02/09/20 11:03 PM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
msd has a kit for locking out!
Re: Race timing [Re: madscientist] #2741538
02/10/20 12:32 PM
02/10/20 12:32 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
I've read some articles on the timing retard issues, not sure which boxes do it though- this one is a msd 6al.
Re: Race timing [Re: dart9ss] #2741578
02/10/20 02:46 PM
02/10/20 02:46 PM
If you don't have a separate starter switch to spin the motor over before turning on the ignition or a ECIU that won't allow the coil to fire until the crankshaft has spun over several times before firing the plugs good luck on getting any motor started that has a lock out distributor with more than 24 degrees total timing scope
Re: Race timing [Re: RustyM] #2741582
02/10/20 02:49 PM
02/10/20 02:49 PM
I remember hearing that at a Mopar drag racing seminar that retarding the timing 4 degrees in high gear would help the car go faster and quicker, I've never had the parts needed to do that shruggy
Maybe with the MSD grid I can do some testing with that to find out wrench luck
Re: Race timing [Re: madscientist] #2741584
02/10/20 03:09 PM
02/10/20 03:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep called slew rate and mine looses about 1 degree every 1000 rpm's towards max...........
Re: Race timing [Re: Cab_Burge] #2741585
02/10/20 03:11 PM
02/10/20 03:11 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I know it works with good quench and 67 heads, and even better with nitrous... Back in the no money days we would stack 2 cheater plates and pull 7 degrees out, car hauled A in high gear. Hitting the timing retard was like another bottle.
Re: Race timing [Re: Thumperdart] #2741597
02/10/20 03:32 PM
02/10/20 03:32 PM
Washington
Washington
Which box are you using Dom?
Re: Race timing [Re: RustyM] #2741603
02/10/20 03:47 PM
02/10/20 03:47 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I have done them both ways, not much difference IMO. My cuda has it locked out w/ a crank trigger. No start retard, cranks fine at 34°. It's an 11:1 compression 575" hemi.
My road runner has the lightest springs and is set at 38°. It cranks w/ less than 38°, but as soon as it fires...it's at 38°. Ran it for years w/ a 14:1 446" wedge and locked out timing.
Never really had any starting issues, but I have big cables and high torque mini starters on both cars.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Race timing [Re: madscientist] #2741606
02/10/20 03:50 PM
02/10/20 03:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
OLD 6200 MSD 6 series w/no chip...........
Re: Race timing [Re: Thumperdart] #2741620
02/10/20 04:26 PM
02/10/20 04:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Big cam = lock it out. Sooo much better idle quality and response. Nice clean idle in gear @ 800RPM. It's a PIA chasing the adjustments with the timing moving around when it has a 15* curve and it's all in at 1500. If it's all in at 1500, why not just lock it and have the clean idle. Any retard needed, do it electronically.
Re: Race timing [Re: Thumperdart] #2741628
02/10/20 04:45 PM
02/10/20 04:45 PM
Washington
Washington
Thanks for the info Dom.
Re: Race timing [Re: Cab_Burge] #2742007
02/11/20 04:20 PM
02/11/20 04:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine starts at 34 degrees no issue, 15-1, ignition on. Actually starts better with ignition on. 1 revolution and it's running. No crank, crank, crank.
Re: Race timing [Re: dvw] #2742068
02/11/20 08:08 PM
02/11/20 08:08 PM
Does your ECU allow the motor to spin over before allowing the ignition to fire the plugs?
Re: Race timing [Re: CMcAllister] #2742084
02/11/20 09:07 PM
02/11/20 09:07 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Interesting thread , mine is locked out as well, MSD digital 6 box has a start retard built into the box, zero issues.
Im curious, what MSD electronics would hook up to the MSD digital 6 box w/ crank trigger to enable electronic timing control from inside the car?
Re: Race timing [Re: RustyM] #2742115
02/11/20 10:51 PM
02/11/20 10:51 PM
AndyF Offline
AndyF  Offline
This is another good reason to switch over to EFI. A Holley Sniper comes out of the box with start retard, high speed retard (or advance if you want), adjustable timing curve or locked timing, etc. Whatever you want to do with the timing curve you can. Even change timing based on air temp or engine temp. And you get built in data logging. With a MSD distributor you have to keep adding boxes or pills or modules to do everything.
Re: Race timing [Re: AndyF] #2742132
02/11/20 11:49 PM
02/11/20 11:49 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
We are hoping to use one on an upcoming build and i'm excited about the tuning possibilities .
On these class/index cars that don't allow them,,, well, gotta do it the old fashioned way- grin.
Page 1 of 3 1 2 3
