Re: Race timing
[Re: RustyM]
#2741391
02/09/20 09:28 PM
02/09/20 09:28 PM
Posts: 179 California, U.S.A.
Torquemonster440
California, U.S.A.
Race only, I'd say lock it out and forget it. If all you're concerned with is wot, locked out seems like the ticket to me.
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Race timing
[Re: RustyM]
#2741401
02/09/20 09:51 PM
02/09/20 09:51 PM
Posts: 4,457 Washington
madscientist
Washington
Msd dist/ 511/ carb - run the fast springs for timing all in early or lock out the dist. - race only car. Thanks If you lock it out and your box retards with RPM you'll be losing power from retarded timing with RPM.
Re: Race timing
[Re: madscientist]
#2741538
02/10/20 12:32 PM
02/10/20 12:32 PM
Posts: 566 Texas
RustyM
Texas
I've read some articles on the timing retard issues, not sure which boxes do it though- this one is a msd 6al.
Re: Race timing
[Re: madscientist]
#2741584
02/10/20 03:09 PM
02/10/20 03:09 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Yep called slew rate and mine looses about 1 degree every 1000 rpm's towards max...........
Re: Race timing
[Re: Thumperdart]
#2741597
02/10/20 03:32 PM
02/10/20 03:32 PM
madscientist
Washington
Yep called slew rate and mine looses about 1 degree every 1000 rpm's towards max........... Which box are you using Dom?
Re: Race timing
[Re: RustyM]
#2741603
02/10/20 03:47 PM
02/10/20 03:47 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have done them both ways, not much difference IMO. My cuda has it locked out w/ a crank trigger. No start retard, cranks fine at 34°. It's an 11:1 compression 575" hemi. My road runner has the lightest springs and is set at 38°. It cranks w/ less than 38°, but as soon as it fires...it's at 38°. Ran it for years w/ a 14:1 446" wedge and locked out timing. Never really had any starting issues, but I have big cables and high torque mini starters on both cars.
Re: Race timing
[Re: madscientist]
#2741606
02/10/20 03:50 PM
02/10/20 03:50 PM
Thumperdart
State of confusion
OLD 6200 MSD 6 series w/no chip...........
Re: Race timing
[Re: Thumperdart]
#2741620
02/10/20 04:26 PM
02/10/20 04:26 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Big cam = lock it out. Sooo much better idle quality and response. Nice clean idle in gear @ 800RPM. It's a PIA chasing the adjustments with the timing moving around when it has a 15* curve and it's all in at 1500. If it's all in at 1500, why not just lock it and have the clean idle. Any retard needed, do it electronically.
Re: Race timing
[Re: Thumperdart]
#2741628
02/10/20 04:45 PM
02/10/20 04:45 PM
madscientist
Washington
OLD 6200 MSD 6 series w/no chip........... Thanks for the info Dom.
Re: Race timing
[Re: Cab_Burge]
#2742007
02/11/20 04:20 PM
02/11/20 04:20 PM
Posts: 9,824 MI, usa
dvw
MI, usa
If you don't have a separate starter switch to spin the motor over before turning on the ignition or a ECIU that won't allow the coil to fire until the crankshaft has spun over several times before firing the plugs good luck on getting any motor started that has a lock out distributor with more than 24 degrees total timing Mine starts at 34 degrees no issue, 15-1, ignition on. Actually starts better with ignition on. 1 revolution and it's running. No crank, crank, crank.
Re: Race timing
[Re: dvw]
#2742068
02/11/20 08:08 PM
02/11/20 08:08 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Does your ECU allow the motor to spin over before allowing the ignition to fire the plugs?
Re: Race timing
[Re: CMcAllister]
#2742084
02/11/20 09:07 PM
02/11/20 09:07 PM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Big cam = lock it out. Sooo much better idle quality and response. Nice clean idle in gear @ 800RPM. It's a PIA chasing the adjustments with the timing moving around when it has a 15* curve and it's all in at 1500. If it's all in at 1500, why not just lock it and have the clean idle. Any retard needed, do it electronically. Interesting thread , mine is locked out as well, MSD digital 6 box has a start retard built into the box, zero issues. Im curious, what MSD electronics would hook up to the MSD digital 6 box w/ crank trigger to enable electronic timing control from inside the car?
