Page 1 of 3 1 2 3
Radiator - Brass/Copper or Alum #2737652
01/29/20 11:31 AM
01/29/20 11:31 AM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
I am looking at putting more cooling into my car, currently has factory brass/copper rad (2 row) . . . I can get factory unit recored with high efficiency 3row, or new brass/copper 3row, OR aluminum 2row or 3row . . . not too concerned about the OE look (the aluminum rad would be painted black to diminish that AL look . . . put just wondering which would give best cooling for the buck ???? Car runs hotter than I like when at highway speeds (about 3/4 way up on temp gauge, but turning on heater helps, so figure not enough cooling from the rad itself) . . . .
Oh, this isn't the Sport Satellite - it has factory 3row 26" with high efficiency rad - cools GREAT !!
Thoughts ???
Re: Radiator - Brass/Copper or Alum [Re: a12rag] #2737664
01/29/20 12:05 PM
01/29/20 12:05 PM
Maryland
mrob Offline
mrob  Offline
Maryland
I had a similar situation with my BB Coronet, so maybe sharing my experience will help. I originally had a 26 inch 3 row radiator and at hwy speeds in the summer (temps in the 90's), the coolant temp would slowly increase the faster I went. To me, that indicated insufficient cooling capacity since airflow is not an issue at those speeds.
So I decided to try a 2 row aluminum radiator. Same core size, 26 inch with 2 rows of 1 inch tubes (think the brass radiator 3 rows of 1/2 inch tubes). On paper, the aluminum radiator has a larger tube surface area which should increase the cooling capacity. After installing the radiator and driving on the hwy at similar temps, the coolant temp was lower than before. With the brass radiator, the coolant temp was about 200-205F and with the aluminum radiator, the temp dropped down to around 190-195F.
Hope this helps. But be aware that your results may vary.
Re: Radiator - Brass/Copper or Alum [Re: a12rag] #2737669
01/29/20 12:10 PM
01/29/20 12:10 PM
moparx Online content
moparx  Online Content
the first thing i would do, is see just what temperature "3/4's of the way" on the gauge really is.
a harbor fright infrared temperature probe would give you a good starting point.
your cooling system may be working ok, but the sending unit or gauge may not be.
as to the radiator choice, it seems the aluminum ones today are the best cooling bang for the buck. champion seems to have a good reputation.
just my opinion. your mileage may vary.
beer
Re: Radiator - Brass/Copper or Alum [Re: moparx] #2737692
01/29/20 12:46 PM
01/29/20 12:46 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
This. iagree
You need to find your starting point.
That being said, I have a 22" 4-row copper/brass in my '65 Dodge (440-6, 727, 3.23) and I have no cooling issues at all. I'm running an OE fan shroud (mid-70's, 6-cyl A-body), and no clutch fan. Car runs 175-185 cruising, 190-195 in traffic. 160 degree thermostat. If you can get a 4-row core for the factory radiator, I would go that route. The 3-row HE should be sufficient, but I prefer 4-rows.
Re: Radiator - Brass/Copper or Alum [Re: a12rag] #2737718
01/29/20 01:42 PM
01/29/20 01:42 PM
AndyF Offline
AndyF  Offline
Copy what you have in your Sport Satellite. If it works then just duplicate it.
Re: Radiator - Brass/Copper or Alum [Re: a12rag] #2737722
01/29/20 01:53 PM
01/29/20 01:53 PM
Copper and brass will, if in good shape, transfer more heat into the air stream than aluminum will.
I went through this with my old pump gas car, the new aluminum cooled better for one summer and then did worse the next summer puke
I had put 50% anti freeze in both but the aluminum lost it ability to shed heat into the air stream over the winter work
I took it to a radiator shop and they did something to make it work for that summer and it did the same thing the next winter shruggy
I will only buy copper and brass now up
Re: Radiator - Brass/Copper or Alum [Re: Cab_Burge] #2737729
01/29/20 02:08 PM
01/29/20 02:08 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I agree with seaBee eek but you can make wrench the alum almost as efficient penguin as brass by running panic a mild flush through it smoke every couple of months wave ... plus the alum is lighter up grin
Re: Radiator - Brass/Copper or Alum [Re: Cab_Burge] #2737742
01/29/20 02:38 PM
01/29/20 02:38 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The textbooks say differently.
https://www.engineeringtoolbox.com/thermal-conductivity-metals-d_858.html
Re: Radiator - Brass/Copper or Alum [Re: jcc] #2737771
01/29/20 03:25 PM
01/29/20 03:25 PM
a12rag Offline OP
a12rag  Offline OP
I do have a handheld infrared temp gun to check the temps . . . will have to do that . . . I ask the question, cause I have "heard" that a 2 row AL would be better than a 3row brass/copper rad . . . personally I would lean towards the 3row brass/copper rad first . . .but, just wanted to get a consensus from the "board"members. . . I have always had good luck with going with the "factory" cooling, including 195deg stat, fan/fan shroud, rad . . . etc . . .
This is going to be part of the springtime, bring the car back on the road . . .right now tucked away for winter . . . uh, car is 64 Ford Falcon convertible with 200 CID 6banger (all stock). . .
Re: Radiator - Brass/Copper or Alum [Re: a12rag] #2737792
01/29/20 04:30 PM
01/29/20 04:30 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
A Furd FailCoon on a mopar site ! .. this is blasphemy! whistling shout xmaseek
Re: Radiator - Brass/Copper or Alum [Re: dOrk !] #2737865
01/29/20 08:40 PM
01/29/20 08:40 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
If memory serves, Falcon 6s had pretty small radiators.
And they were working pretty hard at highway speeds.
It's very similar to a Mustang, and you can buy dang near a whole Mustang from a catalog.
So, I'd check the various Mustang resto-parts outfits & see what's available.
Re: Radiator - Brass/Copper or Alum [Re: jcc] #2737897
01/29/20 10:20 PM
01/29/20 10:20 PM
Did you look at that chart?
I think shedding 392 K at 127 F with copper is way better than shedding 240 K at 127 F with aluminum work scope
I'm not the smartest guy on this site so if I'm reading that chart wrong please help me by correcting my thoughts on this twocents
Re: Radiator - Brass/Copper or Alum [Re: Cab_Burge] #2737914
01/29/20 11:01 PM
01/29/20 11:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think you are mis interpreting the chart. The chart is showing IMO thermal conductivity changes at different "'K", or absolute temp. Its not overly clear. For our interests and temps the last column is useful enough, thermal conductivity, and brass alloy is noticeably less rated then alum, that surprised me because pure copper is much higher then alum.
I also am far from the smartest guy here and somebody else is welcome to take this discussion farther or correct as needed.
Re: Radiator - Brass/Copper or Alum [Re: jcc] #2737918
01/29/20 11:10 PM
01/29/20 11:10 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Fins in a radiator are copper, not brass. the tubes are brass.
copper/brass is better at heat transfer than aluminum. Though that level of better is limited by the lead solder connecting the fins to the tubes but even with that limitation it is still better than aluminum and the design of the fin tube interface can ameliorate the silder issue.
https://www.hotrodhotline.com/content/aluminum-vs-copper-brass-article-us-radiator#.XjJI8Yh7mM8
Re: Radiator - Brass/Copper or Alum [Re: jcc] #2737919
01/29/20 11:12 PM
01/29/20 11:12 PM
I spent 33 yrs in the telephone industry working on the lines and outside plant equipment and finally managing the inside and outside equipment departments providing service to our customers. We always used copper instead of aluminum lines for its better conductivity, the power companies switch to aluminum and increase the size of their lines due to cheaper costs of the lines. Copper does conduct both heat and electricity way always better than aluminum is what our design engineers preached when it came to buying lines or components, gold being the best conductor work
Re: Radiator - Brass/Copper or Alum [Re: Sniper] #2737921
01/29/20 11:17 PM
01/29/20 11:17 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Good article, but I read there tests were done in 1999, I wonder if the current Al. radiators have improved and wonder if the testing has as well?
STOP POTATO HATE!
Re: Radiator - Brass/Copper or Alum [Re: topside] #2737925
01/29/20 11:36 PM
01/29/20 11:36 PM
a12rag Offline OP
a12rag  Offline OP
[quote=topside]If memory serves, Falcon 6s had pretty small radiators.
[/quote
Totally correct - amazing the number of parts available, and how cheap they are !!! . . . I can get complete new rad (brass/copper or alum) from local mustang shop - brass/copper 3row, about $125 less than 2 or 3 row Alum . . .
And so true about that little 200CID, 6cyl, working hard at highway speed - only Ford would make a head with an integral intake manifold for ONLY one tiny carb !!! . . . UGGHHH . . .
Re: Radiator - Brass/Copper or Alum [Re: a12rag] #2737942
01/30/20 01:02 AM
01/30/20 01:02 AM
A collage of whims
A collage of whims
You might also want to pull the thermostat & flush the cooling system.
Check the thermostat opening temp in a pot of water on the stove with a meat thermometer.
Water (I like distilled) cools better than anti-freeze; if you can do 70% water where you live, that helps.
Plus, there are some aero tricks:
1. Cover holes & gaps in the rad support so all the air goes through the radiator.
2. Put an air dam under the rad support to force more air up through the radiator.
3. Vent underhood heat, but it really won't look stock.
$125 for a stock-looking 3-row is a pretty smokin' deal, actually better than I thought.
We should be so fortunate in the Mopar world...
Re: Radiator - Brass/Copper or Alum [Re: Cab_Burge] #2737950
01/30/20 01:25 AM
01/30/20 01:25 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Copper and brass will, if in good shape, transfer more heat into the air stream than aluminum will. I went through this with my old pump gas car, the new aluminum cooled better for one summer and then did worse the next summer puke I had put 50% anti freeze in both but the aluminum lost it ability to shed heat into the air stream over the winter work I took it to a radiator shop and they did something to make it work for that summer and it did the same thing the next winter shruggy I will only buy copper and brass now up
Alum. more prone to corrosion then brass/copper in rads. Also with any/most alum. parts exposed to gases/liquids/contaminants in a cooling system. Alum. oxide is a notorious corrosion to deal with in general. Could it be inside had "some" corrosion that hindered heat transfer & shop "flushed" out that corrosion?
Re: Radiator - Brass/Copper or Alum [Re: Sniper] #2738034
01/30/20 11:16 AM
01/30/20 11:16 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
as per link:
"The thermal conductivity or heat transfer rate of copper is 92% versus aluminum which is approximately 49%. However, the copper fin bonded to the tubes, or water passages, using lead solder is very inefficient and slows the heat transfer rate to just slightly better than that of aluminum."
Doesn't address directly the issue of the lower conductivity of the brass tubes vs/alum.
Explain the method of ameliorating the copper/brass interface to any significant degree in this situation.
I'm also wondering, what exactly does "92%" and "49%" referenced to, pure water?
Page 1 of 3 1 2 3
