Radiator - Brass/Copper or Alum
#2737652
01/29/20 11:31 AM
01/29/20 11:31 AM
Posts: 2,936 Calgary, Alberta Canada
a12rag
I am looking at putting more cooling into my car, currently has factory brass/copper rad (2 row) . . . I can get factory unit recored with high efficiency 3row, or new brass/copper 3row, OR aluminum 2row or 3row . . . not too concerned about the OE look (the aluminum rad would be painted black to diminish that AL look . . . put just wondering which would give best cooling for the buck ???? Car runs hotter than I like when at highway speeds (about 3/4 way up on temp gauge, but turning on heater helps, so figure not enough cooling from the rad itself) . . . .
Oh, this isn't the Sport Satellite - it has factory 3row 26" with high efficiency rad - cools GREAT !!
Thoughts ???
Re: Radiator - Brass/Copper or Alum
[Re: a12rag]
#2737669
01/29/20 12:10 PM
01/29/20 12:10 PM
Posts: 20,235 north of coder
moparx
the first thing i would do, is see just what temperature "3/4's of the way" on the gauge really is. a harbor fright infrared temperature probe would give you a good starting point. your cooling system may be working ok, but the sending unit or gauge may not be. as to the radiator choice, it seems the aluminum ones today are the best cooling bang for the buck. champion seems to have a good reputation. just my opinion. your mileage may vary.
[Re: moparx]
#2737692
01/29/20 12:46 PM
01/29/20 12:46 PM
Posts: 4,114 Yes
sixpakdodge
Yes
the first thing i would do, is see just what temperature "3/4's of the way" on the gauge really is. a harbor fright infrared temperature probe would give you a good starting point. your cooling system may be working ok, but the sending unit or gauge may not be. This. You need to find your starting point. That being said, I have a 22" 4-row copper/brass in my '65 Dodge (440-6, 727, 3.23) and I have no cooling issues at all. I'm running an OE fan shroud (mid-70's, 6-cyl A-body), and no clutch fan. Car runs 175-185 cruising, 190-195 in traffic. 160 degree thermostat. If you can get a 4-row core for the factory radiator, I would go that route. The 3-row HE should be sufficient, but I prefer 4-rows.
[Re: a12rag]
#2737722
01/29/20 01:53 PM
01/29/20 01:53 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
Copper and brass will, if in good shape, transfer more heat into the air stream than aluminum will. I went through this with my old pump gas car, the new aluminum cooled better for one summer and then did worse the next summer I had put 50% anti freeze in both but the aluminum lost it ability to shed heat into the air stream over the winter I took it to a radiator shop and they did something to make it work for that summer and it did the same thing the next winter I will only buy copper and brass now
[Re: Cab_Burge]
#2737742
01/29/20 02:38 PM
01/29/20 02:38 PM
Posts: 23,273 Here
jcc
Here
The textbooks say differently. https://www.engineeringtoolbox.com/thermal-conductivity-metals-d_858.html
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: jcc]
#2737771
01/29/20 03:25 PM
01/29/20 03:25 PM
a12rag
I do have a handheld infrared temp gun to check the temps . . . will have to do that . . . I ask the question, cause I have "heard" that a 2 row AL would be better than a 3row brass/copper rad . . . personally I would lean towards the 3row brass/copper rad first . . .but, just wanted to get a consensus from the "board"members. . . I have always had good luck with going with the "factory" cooling, including 195deg stat, fan/fan shroud, rad . . . etc . . .
This is going to be part of the springtime, bring the car back on the road . . .right now tucked away for winter . . . uh, car is 64 Ford Falcon convertible with 200 CID 6banger (all stock). . .
[Re: jcc]
#2737897
01/29/20 10:20 PM
01/29/20 10:20 PM
Cab_Burge
Did you look at that chart? I think shedding 392 K at 127 F with copper is way better than shedding 240 K at 127 F with aluminum I'm not the smartest guy on this site so if I'm reading that chart wrong please help me by correcting my thoughts on this
[Re: Cab_Burge]
#2737914
01/29/20 11:01 PM
01/29/20 11:01 PM
Posts: 23,273 Here
jcc
Here
I think you are mis interpreting the chart. The chart is showing IMO thermal conductivity changes at different "'K", or absolute temp. Its not overly clear. For our interests and temps the last column is useful enough, thermal conductivity, and brass alloy is noticeably less rated then alum, that surprised me because pure copper is much higher then alum.
I also am far from the smartest guy here and somebody else is welcome to take this discussion farther or correct as needed.
[Re: Sniper]
#2737921
01/29/20 11:17 PM
01/29/20 11:17 PM
Posts: 10,049 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Good article, but I read there tests were done in 1999, I wonder if the current Al. radiators have improved and wonder if the testing has as well?
STOP POTATO HATE!
[Re: topside]
#2737925
01/29/20 11:36 PM
01/29/20 11:36 PM
a12rag
[quote=topside]If memory serves, Falcon 6s had pretty small radiators. And they were working pretty hard at highway speeds. It's very similar to a Mustang, and you can buy dang near a whole Mustang from a catalog. So, I'd check the various Mustang resto-parts outfits & see what's available. [/quote
Totally correct - amazing the number of parts available, and how cheap they are !!! . . . I can get complete new rad (brass/copper or alum) from local mustang shop - brass/copper 3row, about $125 less than 2 or 3 row Alum . . .
And so true about that little 200CID, 6cyl, working hard at highway speed - only Ford would make a head with an integral intake manifold for ONLY one tiny carb !!! . . . UGGHHH . . .
[Re: Cab_Burge]
#2737950
01/30/20 01:25 AM
01/30/20 01:25 AM
Posts: 1,757 Phila
PhillyRag
Phila
Copper and brass will, if in good shape, transfer more heat into the air stream than aluminum will. I went through this with my old pump gas car, the new aluminum cooled better for one summer and then did worse the next summer I had put 50% anti freeze in both but the aluminum lost it ability to shed heat into the air stream over the winter I took it to a radiator shop and they did something to make it work for that summer and it did the same thing the next winter I will only buy copper and brass now Alum. more prone to corrosion then brass/copper in rads. Also with any/most alum. parts exposed to gases/liquids/contaminants in a cooling system. Alum. oxide is a notorious corrosion to deal with in general. Could it be inside had "some" corrosion that hindered heat transfer & shop "flushed" out that corrosion?
[Re: Sniper]
#2738034
01/30/20 11:16 AM
01/30/20 11:16 AM
Posts: 23,273 Here
jcc
Here
as per link: "The thermal conductivity or heat transfer rate of copper is 92% versus aluminum which is approximately 49%. However, the copper fin bonded to the tubes, or water passages, using lead solder is very inefficient and slows the heat transfer rate to just slightly better than that of aluminum." Doesn't address directly the issue of the lower conductivity of the brass tubes vs/alum. Explain the method of ameliorating the copper/brass interface to any significant degree in this situation. I'm also wondering, what exactly does "92%" and "49%" referenced to, pure water?
