Another transmission question shift #2731079
01/08/20 01:43 PM
01/08/20 01:43 PM
Maine
E
exile5700 Offline OP
E
Maine
I have 3 bb transmissions that none are out of a Challenger, will i still be able to use them and use a floor shift? Car has a column shift but was thinking of going with an aftermarket floor shift? Is there a difference between the cases? Thanks for any info!
Re: Another transmission question shift [Re: exile5700] #2731089
01/08/20 02:02 PM
01/08/20 02:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any 727 will accept an aftermarket shifter because they mount on the pan rail or tailhousing. To use a factory floor shifter, the tailhousing has to have the two "bumps" on the bottom for the shifter bracket.
Re: Another transmission question shift [Re: John_Kunkel] #2731099
01/08/20 02:18 PM
01/08/20 02:18 PM
Maine
E
E
Maine
Thank you. Is that just an E body case? or did other cars use it?
Re: Another transmission question shift [Re: exile5700] #2731106
01/08/20 02:33 PM
01/08/20 02:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check out how to videos online on installing an aftermarket auto trans cable operated floor shifter and you will see how to mount it to the trans. Normally it's a bracket that mounts where the tail housing bolts to the trans and a second bracket mounted with the pan bolts.
Re: Another transmission question shift [Re: stumpy] #2731118
01/08/20 02:55 PM
01/08/20 02:55 PM
Maine
E
E
Maine
Will do, thank you.
Re: Another transmission question shift [Re: stumpy] #2731128
01/08/20 03:24 PM
01/08/20 03:24 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I converted my factory shifter to cable on my 68 Charger, work awesome.
Re: Another transmission question shift [Re: CSK] #2731140
01/08/20 04:01 PM
01/08/20 04:01 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Is there a kit to do it??
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Another transmission question shift [Re: Prodart440] #2731167
01/08/20 05:29 PM
01/08/20 05:29 PM
Pattison Texas
Pattison Texas
Not that I know of, I bought a B&M cable & brackets & linkage that goes on the trans, made the bracket at the shifter.
Re: Another transmission question shift [Re: CSK] #2731206
01/08/20 07:09 PM
01/08/20 07:09 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Thanks. I'll look into that!!
Aaron
68 Coronet 440
