Re: Another transmission question shift
[Re: exile5700]
#2731089
01/08/20 02:02 PM
01/08/20 02:02 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Any 727 will accept an aftermarket shifter because they mount on the pan rail or tailhousing. To use a factory floor shifter, the tailhousing has to have the two "bumps" on the bottom for the shifter bracket.
[Re: stumpy]
#2731118
01/08/20 02:55 PM
01/08/20 02:55 PM
Posts: 44 Maine
exile5700
Maine
[Re: stumpy]
#2731128
01/08/20 03:24 PM
01/08/20 03:24 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Check out how to videos online on installing an aftermarket auto trans cable operated floor shifter and you will see how to mount it to the trans. Normally it's a bracket that mounts where the tail housing bolts to the trans and a second bracket mounted with the pan bolts. I converted my factory shifter to cable on my 68 Charger, work awesome.
[Re: CSK]
#2731140
01/08/20 04:01 PM
01/08/20 04:01 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
Check out how to videos online on installing an aftermarket auto trans cable operated floor shifter and you will see how to mount it to the trans. Normally it's a bracket that mounts where the tail housing bolts to the trans and a second bracket mounted with the pan bolts. I converted my factory shifter to cable on my 68 Charger, work awesome. Is there a kit to do it??
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#2731167
01/08/20 05:29 PM
01/08/20 05:29 PM
CSK
Pattison Texas
Not that I know of, I bought a B&M cable & brackets & linkage that goes on the trans, made the bracket at the shifter.
[Re: CSK]
#2731206
01/08/20 07:09 PM
01/08/20 07:09 PM
Prodart440
Avondale AZ
Not that I know of, I bought a B&M cable & brackets & linkage that goes on the trans, made the bracket at the shifter. Thanks. I'll look into that!!
Aaron
